Question about Atwood Mobile Products Atwood G6A-8E 6-gallon Water Heater Electronic Ignition
Heater has low voltage and will not run
I tested from beginning to end and found 12v through the t-stst to the circuit board. From the circuit board to the ECO I have 6v. The solenoid valve needs 12v correct? I put 12v on the valve to function check and it works. Can You Help? Thank You Ron
  • Atwood Mobil... Master
  • 6,674 Answers
Attach black on meter, or ground clamp on test light to good ground such as cooper line. Test for 12vdc at gas valve when switch turned on and you hear or see ignitor sparking. If no 12vdc, backtrack. Follow red wire from gas valve to (ECO), (both terminals,) then same to thermostat (THERM) . If you get 12vdc on one side, and 6vdc or no voltage on the other, replace it. If you've got 12vdc going to gas valve, and don't feel or hear it "Click" when trying to ignite, try a quick "rap" on valve to see if it's stuck. If valve is opening and you hear gas, but no ignition, clean burner tube good and retry.
Posted on Dec 30, 2013
Atwood water heater g6a8e lights but flame goes out after 5 to 10 seconds. I replaced igniter / thermocouple and it worked for a while but problem is back. So I need to replace circuit board?
Make sure you pull connector off and clean it and contacts on board. Be sure igniter is in flame good too. Does it have the thermal cut off in-line? Its the little resistor looking piece inside the plastic cover. If it does, and still running a few seconds and going out, remove it from the circuit, and connect wire end to where you removed cut out from, thus eliminating it from the circuit, and test it. If that cures it, replace that cut-out, as it is a safety device in case of flame up, it cuts gas off to prevent fire. Just leave it out long enough to test it.
Oct 19, 2013 | Atwood Mobile Products Atwood Water Heater...
Hot water element
Make sure wires are removed from element when ohm-testing.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Watt and voltage rating of element appears on end of each element.
Volts squared divided by watts = correct ohm testing.
Two-element water heaters are rated for 240Volts, but can be wired for 120Volts.
Check that water heater is receiving power from circuit breaker box.
So if breaker is 2-pole 240Volt, then check that heater is receiving 240 V across top two screws on upper element.
Replace upper element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Other resources.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Oct 02, 2012 | Water Heaters
The green light goes on, but nothing happens. I'm getting 12v to the controller, but nothing coming out. The thermostat also has 12v in and out. Can I bench test my controller or is even...
Have you tried removing the thermal cut off from the circuit. ( inside the little plastic sleeve ) and wiring it direct to terminal thermal cut off is attached to? Also, try removing the connector at the circuit board and rub the contacts on the board with a pencil eraser and re-try. Sometimes just bad contact at connector tabs. No spark, no 12v to gas valve when turned to ignite, replace board/module.
Jul 01, 2011 | RTO Atwood Water Heater - 6 Gal LP
Low voltage to eco from switch board will not hold valve open
That 12VDC voltage comes from battery and/or converter. Try unhooking battery while plugged in, and see if lights stay bright, as well as check voltage at screw terminals where fuses are in fuse/breaker panel. I f voltage low from converter, check the main fuses at converter. Be sure to check all fuses to circuits as well. You may have a bad or corroded connection from fuse panel to ECO as well. Remove wire from opposite side of ECO where it runs to gas valve, and see if voltage returns to acceptable range, indicating poor connection to valve, or valve drawing too much current.
Let me know what you find.
Mar 07, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a 1992 bounder mh ,6a6e atwood water heater.I recently replaced the coach batteries and main battery.My circuit board went bad,replaced along with eco and thermostat.My gas valve was rusty and...
First check thermal cut-off that is connected between incoming power wire and thermostat terminal. (located inside little clear plastic sleeve) Easiest way to do that is to remove it from the circuit temporarily. Just pull it off thermostat terminal, pull it apart from other end, and just connect female spade from incoming power wire directly to thermostat terminal. Then see if water heater ignites. If it does, and all works well, get new thermal cut-off. That cut-off is a safety feature in case of flame up at burner, it will shut off gas supply. It is not reset-able, just works once then needs to be replaced.
If that doesn't cure it, take a 12v test light, or a multimeter, and test for power at gas valve, when water heater is trying to ignite, or at ECO terminal where red wire runs from left ECO terminal to gas valve. If power is getting to gas valve, and you don't hear or feel it click, make sure ground connection is sufficient as well. If you have 10.5-13.5 volts to gas valve, and it's not opening and ground is good, then it's faulty and should be replaced. If it is clicking, (opening) but no gas coming through, you may have a plugged orifice on gas valve, provided you have cleaned burner tube of any spider webs or debris previously. If no voltage from red wire, start back tracking with meter or test light to other terminal on ECO, then to terminals on thermostat as well. You'll see how feed wire (short jumper) goes from thermostat, over to ECO. Remember, you will have to hold test light or meter probe at connection and have someone turn on switch to get a reading, which will only appear when it's trying to ignite. Let me know what you find.
Dec 05, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The tank less water heater-Riannai Model#MC-91-1US-S is bleeping with an error code of 12 when the hot water is turned on. I have checked the breaks but else can I do?
Correct me if I am wrong but you have and error code 12 immeadiately you turn the tap on.
If so you have a short circuit on the low voltage side of the system. Usually this is somewhere on the wiring to your remote control pads. Easy way to test is to turn the power off, that is unplug the power lead to the heater. Take the cover off the front of the heater. Locate where the leads that supply the controllers conect in to the heater. Older models this will be on the circuit board, newer ones right at the base of the casing. You need to disconnect this wring (not the main power supply lead). Once done put the case back on and give the heater a try. If the problem is gone you have a short circuit on the wiring to controllers or a fauly controller. If the fault remains you have a short circuit on the low voltage side inside the heater. Likely need a technican to find this but tell himto start with the wiring to the the overheat thermal fuse that goes around the heat exchanger casing.
Aug 17, 2010 | Water Heaters
How to reduce 12v AC to 10v Ac
The simple answer to reducing 12V ac to 10V ac is to use a transformer, however, noting that your question is in relation to a water heater, I am assuming that you are troubleshooting and have found a voltage of 12V that you expect should be 10V.
If this is an AC power source, normally, a voltage variance of this magnitude (around 15%) would not be considered significant. The voltage itself would have been transformed down from the supply voltage (via a transformer) and a + 15% overvoltage on the grid would not be uncommon in many lands, particularly outside of peak load periods. This could account for the variance that you have identified and would be a 'normal' operating condition.
On the other hand, if you are troubleshooting electronic components on a printed circuit board you might actually be measuring a pulsed DC signal and will obtain spurious readings on both AC and DC ranges on a standard multimeter. In this case, the measurement doesn't tell you much.
Mar 10, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Operates on propane but not o 110v,circuit board appears to be operating correctly when 110 v switch is on
THE CIRCUIT BOARD IS FOR THE 12V SIDE OF THINGS THAT OPERATE THE IGNITOR AND GAS SOLENOID VALVES. HAVE U MADE SURE THE CIRCUIT BREAKER AT THE CONVERTER BOX IS ON? HAVE U LOOKED AT THE BACK OF THE WATER HEATER AND MADE SURE THE SWITCH IS IN THE ON POSITION? IF EVERYTHING IS ON AND U KNOW THERE IS POWER GETTING TO THE WATER HEATER, TRY OHMING OUT THE ELEMENT WITH AN OHM METER. ELEMENT IS LOCATED UNDER THE BOX BEHIND THE WATER HEATER. MAKE SURE POWER IS TURNED OFF AND THE WIRES ARE DISCONECTED BEFORE USING OHN METER.
Dec 11, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood GCH10A-4E won't heat in electric mode. 12v power to circuit board no 12v power to relay. Is new circuit board only solution?
CHECK THE FUSES AND CIRCUIT BREAKERS IN THE CONVERTER BOX. MAKE SURE THE 110V SWITCH BEHIND THE WATER HEATER IS TURNED ON. IF THERE IS POWER AND "ALL" THE 110V SWITCHES ARE ON, TIME TO OHM OUT THE HEATING ELEMENT, LOCATED UNDER THE BOX BEHIND THE WATER HEATER.
IN ORDER TO HAVE 12V AT THE CIRCUIT BOARD, 112V POWER HAS TO GO THRU THE RELAY. SOUNDS LIKE U HAVE A WIRING PROBLEM SOMWHERE, EITHER AT THE SWITCH OR AT THE WATER HEATER SOMEWHERE.
Dec 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood Mobile Products Atwood G6A-8E 6-gallon Water Heater Electronic Ignition Logo
88 people viewed this question
Top Atwood Mobile Products Water Heaters Experts
Donni Steen
Gil Shultz
Are you an Atwood Mobile Products Water Heater Expert? Answer questions, earn points and help others
