Question about Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged
I need to download a manual for my ingersoll rand upright compressor, model number 2545. Can anyone help?
  • 98 Answers
Call I.R and they will send you a manual for a small charge.
Posted on Jul 21, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Pump direction of I R model 2545
check the fan pully blade angle the air must blow over the pump
Mar 08, 2014 | Ingersoll Rand 2545 Pump,air Compressor...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Looking for parts list. missing strart capasitors etc.a manual or schedule can help me out.need to buy some parts ingersoll rand dd2t2
Hi johnny camer.
Sorry I could not find a parts list for your compressor model
But I found the ingersoll rand contact number, you can call them and talk to them on the net and get the right parts and manual you need.
Please take time to rate me
http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31052
Aug 31, 2011 | Ingersoll Rand DD2T2 T Win Stack Single...
Belt number for a T30 series Model 2545 we need to replace the belt as it is getting old. Which v-belt is the proper fit?
you will have to look at the belts that are currently on the machine and get the numbers off of it or take it to a place that sells belts they would be able to size it up and find the correct replacement do not go to ingersoll rand if you can avoid it cause they are expensive
Jul 06, 2011 | Ingersoll Air Tools & Compressors
I have an Ingersoll Rand 2545 Electric Air Compressor and since the summer started it runs all day(won't shut off). At night it seems to cycle correctly but when the heat builds up during the day...
I don't know if your unit is exposed to the direct sun light if it is I suggest you create some shade , or if this this unit is enclosed is not getting enough air flow to keep cool.
( this air flow helps to stabilized the sensor that stop and start the compressor )
Sep 26, 2017 | Ingersoll Rand 2545/7100 Electric Air...
Model 2545 compressor getting toomuch carbon deposit in side the cylinder
You can try switching to a full synthetic compressor oil to alleviate the problem.
Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
Regardless of the problem synthetic compressor oil will help.
Hope that helps,
under_psi
May 16, 2010 | Ingersoll Rand - Rand Type - 30...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
How to reasseble the open compressor model esv 7*5 by own. we dont have repairing manuals.its an second hand purchased compressor
Not what you want to hear, I'm sure, but I'd recommend contacting your local Ingersoll-Rand distributor. These double acting, water cooled machines require substantial expertise.
A unit of this size (probably 20-25HP or so) is probably going to cost more to rebuild than a new screw compressor costs. However, they can be very efficient machines.
Oct 28, 2009 | Ingersoll Rand 2545/7100 Electric Air...
Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged Logo
638 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
