Question about Ricoh Aficio SP-C210SF Printer
Reset kit maintenance ricoh sp 4200 - Ricoh Aficio SP-C210SF Printer
  • 9 Answers
SOURCE: ricoh aficio ap410n printer, Replace Maintenance Kit
unbelievable... you guys charge for discussion??!!! get real! i'll find one of about 1,000 free places where i can discuss this and find an answer....
puleeze
Posted on Feb 29, 2008
Ickoajnc
  • 183 Answers
SOURCE: Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Posted on Jul 16, 2009
  • 15 Answers
SOURCE: how long will a ricoh sp 8100 run with a replace
Normally, maintenace kit A and B are replaced at 150K copies. However, you can keep on truckin! Eventually the copy quality (blk lines, dirty copies) will degrade. Also, you might get fuser issues (error codes, jamming).
Posted on Apr 16, 2010
SOURCE: replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Posted on May 14, 2010
  • 393 Answers
SOURCE: Ricoh Aficio SP C411dn error SC542
It represents a fuser (hot section) failure you must enter service mode to reset. New fuser time?
Posted on May 17, 2010
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
How to enter into service mode ricoh 8300dn
Ricoh SP8300 SP mode (Service Mode)
To Enter SP Mode (Service Mode)
Do one of the following:
If the power is already ON, press the "Home" and
"Simple screen" keys at the same time for more
than 3 seconds, and then press the "User tool"
key.
or
If the printer is OFF Press the "Home" and "Suspend" keys at the
same time while turning the main switch on.
Reset for Maintenance Kit A or Maintenance Kit B
So the "Replace Maintenance Kit A" or Replace Maintenance B" message will go away.
Once in SP Mode (Service Mode) press the following:
"ENGINE"
"SP-7XXX" - "DATA LOG"
"7804" - "PM Counter Reset"
"6" - "ALL CLEAR"
"EXECUTE"
Jan 13, 2014 | Office Equipment & Supplies
How i reset maintenance on ricoh aficio sp 4310n
The machine will automatically reset the maintenance message when the fuser is replaced.
There is a looped wire on the fusing unit connector containing a thermo fuse (a thin wire that quicly melts, and then short the cirquit).
If you don't want to replace the fuser yet, you can probably set the machine to meter charge, SP mode 5930, and then reset the maintenance counter with SP mode 7804.
You can of course take out the fuser, and replace it with a dirt cheap thermo fuse bought from Ebay. Then set the fuser back into the printer, and it will clear the maintenance message automatically.
Either way should work fine, at least it used to do that on the previous model - and it is almost identical.
Dec 20, 2011 | Ricoh Aficio Office Equipment & Supplies
I replaced maintenance kit a and b on a Ricoh sp 8200dn, but it still tells me to change the maintenance kit on the screen. Is there an SP Mode to clear this. I tried SP5507/10 to 1 and SP 5507/11...
Off hand I'm not certain what maintnance kit is type B but you can try resetting the PM counter at SP7804
001 - Is for Paper
002 - Is for PCD (Drum / Dev unit) except developer
003 - Is developer
004 - Is Fusing
005 - Is Web
006 - All Clear
Aug 31, 2011 | Ricoh Type SP 8200 B Maintenance Kit...
How to reset maintenance counter after kit installed.
If you have installed new maintenance kit, then the PM call should be reset automaticaly(there is a fuse in fusing unit).
You can reset manually in service mode:
Press and hold UP and DOWN arrows buttons together for about 6 sec. Then release it and press immediately ENTER button. Now you have to see SERVICE MODE.
Navigate with narrows and OK buttons to SP7 DATA LOG and look for PM_CALL_RESET. There you can reset whatever you want. The EXIT with escape button or restart printer
Write me for help if something goes wrong
pifonski
Mar 03, 2011 | Ricoh Aficio SP 4110N Laser Printer
How long will a ricoh sp 8100 run with a replace pm kit error code?
On most similar Ricoh models, the "replace PM kit" message will keep flashing until the PM kit is replaced, but this shouldn't hinder operation at all. The machine will keep running until one of the parts breaks down, which depends on how old everything is and how hard it is worked.
Basically, the flashing message is a reminder to replace the maintenance kit as a preventative measure, but it does not NEED to be done until something actually breaks.
May 14, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Ricoh Aficio SP C411DN printouts can be rubbed off of paper or lables
Fuser pressure roller is worn. Fuser is sold as part of the "maintenance kit"
Apr 16, 2009 | Ricoh Aficio SP C411DN Laser Printer
Ricoh Aficio SP-C210SF Printer Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
