Question about Refrigerators
Whirlpool gold conquest side-by-side refrigerator water not working
The water dispenser is not working, but the ice maker works properly. The light does not come on when the water lever is depressed, but it does come on with the ice lever.
  • 2 more comments
  • Bob G Nov 28, 2012
    Model No. GS5SHAXNB00
  • Richard Roth
    Richard Roth Nov 28, 2012
    OK, you will need to replace the interface board on the unit. Here is the part to order.http://bit.ly/Rja31Y
    Thanks Richard!
  • Richard Roth
    Keep me posted!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Water dispenser of my Whirlpool
Here is what you can do to test the water. Open the back lower part of your unit by removing the fiberboard cover. Unplug your refrigerator for at least 10 minutes and swap the 2 connectors on the water valve as-sy. Then apply power and try the water through the door. If you get water at this point then one solenoid is bad on the water valve. What your doing is verifying that the water switch for the glass is working and providing power to the water valve solenoid. All your listening for is ANY water flow either through the ice maker tubing or the water in door when you actuate the water in door arm. If you still do not get water the in-door water micro switch or wiring has a problem.
Make sure when you power off again to switch the connectors back on the water valve and install the back fiberboard panel that you wait at least 10 minutes before re-plugging the wall plug. You must wait for the coolant system to stabilize. Otherwise the compressor thermal overload will continually trip and the compressor will NOT re-start.
This manual will help you determine the problem if the above did not already confirm what has failed.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa
Kelly
Posted on Oct 18, 2010
richroth
  • 9472 Answers
SOURCE: Whirlpool Gold side by side, ice maker works, will
The problem could be with the icemaker itself or with one of the controls that supplies power to the icemaker. It could also be a temperature problem. If the freezer temperature gets above 10 degrees, it won't cycle. You can check the temperature by placing a thermometer between some packages. Air temperature is not a good check. For more specific information, a complete model number will be needed.
Posted on Jan 21, 2011
woodchuck789
  • 4070 Answers
SOURCE: We have a whirlpool gold
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Whirlpool conquest g56sha not making ice
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water dispenser and the ice maker have stopped working on my Whirlpool Gold GS5SHA. I have cleaned and defrosted the ice maker. The lines look clear. Any suggestions? Thank you.
Hello Kent, with the work you were doing on your frig did you shut off the water valve and just forget to turn it back on. This is a very common problem. Check and see, GOOD LUCK.
Oct 11, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My side-by-side Whirlpool Gold is not making ice.
could be bad solinoid, only letting water to dispencer, u could switch sol leades to see if water goes to ice maker, but check ti make icemaker is on first
May 29, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not working properly
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser working but ice maker not working
is water is in side ice maker if not check hose at the back if water in icemaker call for service
Mar 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
