Question about Bernina Virtuosa 160
Needle is bumping into plate
Hello- I am a very amateur sewer, though I've been around sewing all my life, my mom being an expert. I've just bought a Virtuosa 160, Home Art Edition, on eBay, wanting a good machine but trying not to spend too much. Now that I have it, I am having some trouble to see if it will work. At first, I attempted to thread it and raise the bobbin thread so that I could test the stitching, but I got the threads stuck in the bobbin area, which pulled on the needle and snapped off the end of the needle. Now, I replaced the needle, but the tip of the needle does not go into the recess of the plate, but bumps into the plate a hair's breadth away from the recess (hole). I've adjusted the needle to make sure it's in all the way, and that it's facing the right direction, the presser foot seems to be in all right, and I can't seem to be able to adjust anything else. I cannot find anything in the manual or on the internet to give me any ideas of what I should fix, or what I have done. I would greatly appreciate any help, and advice on this model in general- -thanks!
    Novelist:
    Scholar:
  • 84 Answers
Hi keenz...Since you've proven that you understand the proper direction to insert your needle, there are only 2 other options available for you to do. 1) Once again, replace the needle with a new one. If the needle's that you have, came in a paper pack, the chances of them being deformed are quite high. Sewing machine needles should be of high quality, and be packaged in a rigid plastic tray with individual slots for each needle, such as those manufactured by Schmetz. If you are confident in the integrity of your new replacement needle, does the replacement produce identical results? If yes...... 2) Visually scrutinize the Stitch Plate alignment and seating, and use your hand to feel the countours of the Plate against the Bed. You shouldn't be able to feel much difference either forward or backward, and there should be zero tolerance if you sweep your hand across the Bed and over the Needle Plate. If you are confident in the integrity of the Needle Plate alignment and placement, than your machine will have to be serviced by a technician, because what has occured is when your threads knotted (due to improper threading and/or failing to remove any thread slack prior to stitching), the rearward motion of the fabric as the Feed Dog was doing it's job, versus the needle being held by knotting, has caused your Needle Bar to become misaligned. Please update your post with any developments.....good luck my friend
Posted on Aug 04, 2007
SOURCE:
Bernina service manual for Virtuosa 160
Here is a link to a sewing machine part company where you can order the manual. It is $19, but I think well worth it if you have the machine. Good luck! That is a nice little machine. http://www.sewingpartsonline.com/instruction-manual-bernina-virtuosa-160.aspx
Oct 16, 2014 | Bernina Sewing Machines
Where can I find an instruction manual for bernina virtuosa 160?
Aug 07, 2014 | Bernina Virtuosa 160
Where do I find an extension platform for my Bernina Vituosa 150?
I'm sure there are several people making these. They are expensive though. I would try Ebay first.
Oct 24, 2012 | Bernina Virtuosa 150
The timing on my bernina virtuosa 150 has gone
retiming a machine needs to be done at a sewing machine repair shop
Mar 29, 2012 | Bernina Virtuosa 150
My bernina (home art edition 160) needle just hits the case where the bobbin goes in, didn't know if anyone knows how to fix this?
if you've changed the needle & it still hits the bobbin case then it's a good chance the machine is out of time & needs to be repaired
Feb 23, 2012 | Bernina Sewing Machines
New home h f 106 sewing machine
I suggest to go to Ebay and search for New Home Sewing Machine. If you find one like yours, contact the seller and maybe he/she can help you with what you're needing to know. Sorry I can't be of any help. I own all Singer sewing machines. They've been great machines for me and I've been sewing for over 40 yrs. Good luck. Aria
Nov 14, 2011 | Sewing Machines
White Classic 312 - I turned on machine, reloaded bobbin and put it back in. Threaded needle, tighted needle arm after threading bobbin and pushed on peddle to start sewing. The machine locked up,...
Bake cookies. This is why you never paid attn when Mom tried to teach you in 1977, and why sewers are on a higher mental plane than yourself, Pammy.
Aug 12, 2011 | White Sewing 312 FS
I have a Singer 5430c and the needle plate is broken . I need a new needle plate.
They can be bought for around $28 online. Or else call Singer at 1-800-4singer and order from them
Feb 20, 2011 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
204 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
