There is a smell of fumes. how do I service this problem. It is a kozy world wall gas unit, with 3 burners.
There is a fume smell that burns your eyes.
  • 57 Answers
Take sm. bowl and mix dish soap and water real bubbly,turn on gas,take sm. paint brush and paint soapy solution on all heater joints that contain gas and watch for bubbling bubbles,and thats where your leak is,but don't stop with the 1st leak you find,there may be more..check all joints, start with house plumbing then factory heater piping,,once all found ,mark them as you find them...then shut off gas and reseal and or retighten leaky joints....
Posted on Nov 28, 2012
tinytrees
  • 92 Answers
SOURCE: fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Posted on Jan 23, 2009
SOURCE: heater produces bad smell and fumes that make our eyes burn
Hi I hope I can help you with your heater. I own 3 of them. Once you light your heater, give it time to completely light around the ring. Once it does, adjust your burner so the flames are evenly around the ring. Make sure you are using 1K kerosene too. That makes a big difference in the use of your heater. If I can help you any other way please feel free to contact me.
Posted on Mar 02, 2009
tbugger
  • 232 Answers
SOURCE: How can I adjust the pump screws to get less fumes?
www.reddyparts.com has instructions for setting the pump pressure.
Posted on Mar 09, 2009
  • 118 Answers
SOURCE: The pilot light on my kozy world ventless wall
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Posted on Oct 26, 2009
koolbreezes
  • 540 Answers
SOURCE: raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Posted on Dec 18, 2009
Strong fumes from new frigidaire gas oven.what should i look for
If it smells like gas Shut the gas off outside call installer, or
gas company. If it doesn't smell like gas, most likely it's the "new smell" caused by the heat. If you have a kitchen vent fan turn it on. If it persists Call the installer or dealer. No action by them? call the mfg customer service number in your owner's manual. It's possible something was left in the oven burner area that shouldn't be there.
Feb 27, 2015 | Frigidaire Kitchen Ranges
1999 jeep smelling gas fumes and blows out black smoke.
burning very rich, is the check engine light lit?
Sep 08, 2012 | Jeep Cherokee Cars & Trucks
Burns yellow and has an exhaust smell/Not propane but an ezhaust smell that gives me a head ache and sore throat. I need an answer now as it is frezing and snowing.I have no heat. It is a lp wall unit.
The burner could be blocked the air ports are clogged lack of air to burner casing to burn yellow, or you haveproblems with you reg , ie low pressure, It sounds like its giving off fumes , needs to be looked at by a gas fitter asap.
Feb 27, 2011 | Williams 18065119 (LP) Gas Heater
When on gas smells of exhaust fumes in van and
sounds like the burners need a good scrub to clear carbon off jets.
May 07, 2010 | Thetford Norcold DE0051 Refrigerator
When the dryer in on I smell fumes.The flex hose was removed and there is nothing in it. The fumes do not smell like gas fumes such as from a gas leak It is an older Kenmore dryer that woeks fine.
Did you recently do some painting or varnishing in the house? These and home perms will mix with the burner and leave an awful smell behind.
Eric
Aug 08, 2009 | Kenmore Dryers
Smelling fumes from 4xl55. Also cycles many times b4 igniting.
Hi jim if you are smelling fumes turn it off and get a service done on it asap
Mar 27, 2009 | Dayton Gas Furnace Heater
Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Jan 14, 2009 | Heating & Cooling
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
On a standing pilot, coleman gas furnace, when burner fires, the flame burns wildly on high burn. Could this be because the air adjusment is set incorrectly? In a short time it blows out the burner, and...
HEY J, this could be a dangerous situation. You could have a crack or rusted out heat exchanger, if this unit is over 20 years old, which it is because it a standing pilot, units are obsolite! This could be letting in CO2 ( carbondioxides-- poision gas fumes) n, Oklahoma, our gas co. will come out for free to give our units a CO2 gas fume check anaylsis. Check this out before someone dies or ill repairable damage done to the body! Thank-you-very-much!
Aug 30, 2008 | Coleman Heating & Cooling
Oven fumes
HI ,
Align the burner to gas nozzle at the back side cover , if still ajusment make it closer nozzle to burner so that gas will not spell out,
Dec 19, 2007 | Hotpoint RGB745 Gas Kitchen Range
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
