Question about Pool & Spa
Blower motor noise
High pitched whine when blower motor is on
    New Friend:
  • 72 Answers
Clean out the blower with compressed air. Check to ensure nothing is stuck in the fan blades.
Posted on Nov 30, 2012
Intertherm furnace model m3rl060abw blower makes high pitched whine when running. why? how can i fix it?
not familiar with that specific model, but if it's high pitched, it is likely the induced air blower causing it. sometimes it is possible to disassemble the motor and clean and lubricate it, but the repair that most service personell will do is to replace the motor. often it comes as an assembly which includes the motor and fan.it's the easiest, longest lasting, and quickest solution.
it is possible that it is the circulating blower with a seized bearing causing the whine. if so, the bearings (and shaft) can be replaced.
Jan 27, 2013 | Heating & Cooling
High pitch whine from belt area on 03 roadstar
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Shifting Trans---CLUNK
7. Gears---WHINE
8. Front Forks---PLUNK
9. Rear Shocks---SQUEAK
10. Starters---CLICK
11. Solid Lifters---TICK
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Re Chirp and High Pitched Whine Road Star Forum Yamaha Road Star
High pitched squeal Video included
http://www.werder.ee/Manual/XV1600.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/lit-11626-16-44_361.pdf
Jun 05, 2012 | 2003 Yamaha Road Star Silverado
Amana GULA 90 Furnace Motor noise & BAD smell
Your ears should tell you which is at fault.
Nov 18, 2017 | Heating & Cooling
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Dryer still heats up, but it sounds like the motor is making a high pitch whining noise?
something might be hitting the blower wheel or the wheel could be cracked,remove the bottom panel,take out the lint filter and remove the duct that the filter slides into, start the dryer and check the blower wheel to see if it's that or the motor,clean out the duct and vac out the inside of dryer while you're in there,blow out the vent line,do this once a year and you'll have less problems with dryer and no fires
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
