Question about Icom IC-706MKIIG
My ICOM 706MKIIG will not power up? Since ICOM does not support this model any longer, is there anyone who knows how to fix this unit?
  • Nyte_Ryder Apr 18, 2017
    The ICOM 706MKIIG has a couple of rubber cushion pads under the PLL board and the glue on these pads if subjected to moisture will in time turn the glue to acid and this will eat the circuit traces under the pads clean off the board. I have fixed more than a half dozen of the 706 radios that these pads had totally dissolved the circuit traces that came in contact with the glue. You will need to remove the PLL board to check these pads and take them off the board, clean off the residue and check with a good magnifying glass and also ohm across the traces to verity that the traces are ok. Bet you will find a trace near the +5 volt regulator ate in two! Good luck with your repair. 73, Dennis
    New Friend:
  • 18 Answers
Yes, I do. They are not easy to work on, and depending on what caused the problem, they can be expensive to repair. Take the covers off and check the fuse. If it is open (the wire inside is broken), replace it with another of the SAME value. A larger value will just cost you more in repair costs! If the fuse blows, then your best to take it to a service tech.
Posted on Dec 09, 2016
How do you recalibrate the SWR meter in an Icom 706Mkiig radio. I changed the filter board and it seems off now.
You will need the service manual to be able to do this and you will also need to purchase a 150 ohm carbon film resistor (no wire wound resistors) to simulate a 3:1 SWR to reset the onboard auto tuner base line for SWR. I believe you may find a service manual on BAMBA's website to download for free. The auto tuner is factory set to work up to a 3:1 SWR before it gives up trying to match the antenna. So, this is a resistor you will need or make up a 150 ohm load using a combo of resistors as long as they are not wire wound types. 73, Dennis
Mar 31, 2017 | Icom Radio Communications
Polarity reverse problem in icom 706 mkiig
Quite a few things can go wrong in this situation. There is an internal fuse that can blow, but the first problem will be a rather large diode that is directly across the DC power input. Reverse polarity will cause this to short, and it usually stays shorted. It will need to be replaced. Then, you should look for open traces from the +12V line to the fuse holder, and the collector of the HF output transistor. If you do not see close to ZERO ohms when your leads are attached, then you have a trace blown off the board.
Depending on how long you left the reversed power on, and if you replaced the inline fuses with a larger value, repair cost can run you from $2 to several hundred, just for the parts! I would take it to someone that knows how to work on this radio. It is not an easy radio to work on.
Jul 06, 2014 | Icom IC-706MKIIG
My icom 706 will not transmit on HF but ok on vhf
Puts out about 5 watts on all bands into a "Dummy Load"
Sep 08, 2013 | Icom IC-706MKIIG
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
ICON 706MKIIG Radio no power up
Check the internal fuse. It may have blown. Other than that, I would suggest you take it to someone that works on these radio's. They are very difficult to work on if one isn't proficient in working with surface mount devices.
Feb 25, 2013 | Icom IC-706MKIIG
Email Whistler at for info on that model. Do you think its the power cord or the jack in the unit itself?
Dec 26, 2007 | DE-1675 Radar Detector
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
Icom IC-706MKIIG Logo
314 people viewed this question
Top Icom Radio Communications Experts
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
