Question about MTX Thunder 4500 T4510-04 Car Subwoofer
How many watts will the 10 inch mtx thunder 4000 have
I need to know how many watts one 10 inch mt thunder 4000 subwoofer so i know how big odf an amp i need
    Sergeant:
  • 344 Answers
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Posted on Nov 28, 2012
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: i need to no how
I hesitate to answer this question for fear that you will not like the answer even if it is the truth. I have received a bad rating from a couple of people in the past just because the right answer was not what they wanted to hear.
This is a mono sub-woofer amp, which means that it is already bridged internally. You only have one speaker output in this amp, that means that the amp circuit is bridged inside, it is not split into two channels.
To bridge any output, it requires 2 channels, otherwise there is nothing to bridge.
I have been repairing car amplifiers for over 18 years, and I promise you that there is no way to bridge a single channel amp. Bridging means to convert 2 channels into 1 channel. If all you have is one channel, then there is nothing left to bridge.
I hope this explains it for you, if you have any other questions feel free to post them here and I will answer as soon as possible.
And please do not punish me with a bad rating if you do not like the answer, it is the correct answer, and sometimes the right answer is not always what we want to hear, but it does not make it wrong.
Dave
Posted on Nov 09, 2008
SOURCE: Picking the right amp.
go with mono amp like me in my pliot.with JL 500/1 Amp..Done
Posted on Feb 24, 2009
  • 32 Answers
SOURCE: 2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Posted on Feb 12, 2010
  • 3 Answers
SOURCE: how big of hole do i need for the mtx 6000 thunder
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Posted on Mar 01, 2011
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
How big of hole do i need for the mtx 6000 thunder 10in
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
I have one mtx t4510-04..what amp do you
Hello jandytaala,
The recommended power range for you T4510-04 is 112.5 to 225 watts RMS. So you need a monoblock amp within that range. You could go up to about 300 watts RMS, but watch the gain and don't try to get too much from a single 10" sub.
The Orion Cobalt shown here would be a good match and is only $139.99. For another $60, the Alpine MRP-M500 will output 300 watts into 4 ohms.
Hope this helps.
Aug 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
yes you could go with a 2 channel. You could alwayse bridge it.
Jan 07, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
MTX Thunder 4500 T4510-04 Car Subwoofer Logo
180 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
