Question about Acer Emachines E627-5279 15.6" Glossy Lcd Panel
My emachine E627 cooling fan is not functioning. What do I do?
When I started turning on the notebook, it took about 30-50 minutes to start up. I also noticed that i heard nothing at the start up, the system fan was not running. Nothing but dead silence.
  • Acer Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Nov 28, 2012
I dont know how to turn on my webcam on my emachines e627
it should works automatically. If you go to my computer sometimes you'll find a WEBCAM icon: Double click to start your webcam.
In case that you dont have the drivers Go to this site : Choose Notebook/E/E627 to get your webcam drivers
http://www.emachines.com/support/drivers.html
Nov 20, 2010 | eMachines Computers & Internet
Emachine E627-5583 does it have a built in microphone?
The best way to check is to click on Start menu> right click on Computer/My Cpmputer> Properties> Device Manger and check if the webcam is listed in it. If it is listed then the computer has Web cam.
May 08, 2010 | Acer eMachines 520-2890 Notebook
I Have an Emachine E627 Laptop and I'd like to use my webcam
I have an emachines e627 and it has a webcam, because there are different models of the emachines e627. Most likely you have an emachines e627-5583, that model has a webcam. If you are trying to use your webcam there is a program that is built in called just go to "C:\Windows\Video Web Camera.exe". I hope this works for you
Dec 29, 2009 | Acer eMachines 520-2890 Notebook
I just bought a Emachines E627 and I can not get my camera to work
The e627 doesn't come with a camera, look at the box because it even states there it doesn't have one.
Nov 30, 2009 | E-Machines M2350 Notebook
I have a notebook emachine E627 and i dont know how to use the webcam?
you can't, you don't have a webcam the e627 does not have webcam.
the best way to know im right, get the box and look at the spec where it says wlan, wwan, bluetooth and right there webcam it'd be NO.
Nov 27, 2009 | Acer eMachines 520-2890 Notebook
Acer Emachines E627-5279 15.6" Glossy Lcd Panel Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
