My whirlpool cabrio wtw6600sw2 type 580 washer is making a terrible spinning grinding noise when in the spin cyle. It is sooo loud - I am figuring it is a bearing or something but it is only 4 years old and a bearing should not be going out already...what can I do to fix this -any help would be appriciated.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
I am a Sear's tech and it is the bearing more than likely, I also own a cabrio myself. Is it a loud, constant roar when it spins? If so you have to replace the tub itself, comes with the bearing. Pretty time consuming job, but I've done several of them. The tub might have a 10 yr warranty, check your owners manual. If not, here is the tub to order.
The tub comes as a complete kit with all the seals and bearing.
Keep me posted!
Posted on Nov 28, 2012
  • rkeily
    rkeily Dec 06, 2012
    well I ended up calling whirlpool who sent a tech out - he says its the bearing like we both thought it could be, its a 85 call and 285 in parts n labor - i agreed because I don't want the hassle of tearing it apart and doing something wrong - they come back in 2 days to fix it - I will keep you posted. thanks for your help and answer.
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
  • 111 Answers
SOURCE: Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Posted on Jul 13, 2009
jonniewalker
  • 1029 Answers
SOURCE: Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Posted on Aug 20, 2009
  • 57 Answers
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
Posted on May 18, 2010
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cabrio won't spin
its SD not 5D
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
511 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
