Question about HP JetDirect EX Plus Print Server
Radeon chipset AGP vid card and nForce 3 250 chipset motherboards
Trying to find a 512mb AGP video card to squeeze a little more life from my nForce 3 250 chipset board/AMD Athlon 64 3400. Tried a Powercolor Radeon HD3850 but could never get it to install correctly (used drivers from CD that came with it, dowloads from ATI including hotfix drivers, and custom Omega drivers). None let me get back into XP Pro sp3 destop. Safe mode and System restore got me back up with my old nVidia 6600GT AGP card.
Anyone know of a 512mb AGP video card that will work with nForce 3 250 chipset motherboards? Mine is a Biostar K8NHA Grand.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 2,226 Answers
Nvidia card sould work check to see if it is a 4 6 8 16x agp socket first then get one that will work jim
Posted on Mar 26, 2010
I am a gamer and p5vdc-mx has only agp slot and i want 1gb vga card but it is harder to find in agp slot i find only pci express x16 cards can i use riser card to convert agp to pci e x16
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
Sep 07, 2011 | ASUS P5VDC-MX Motherboard
For
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from www.playtool.com. I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
www.american-media.com
Pentium 4 3.06Ghz
1G RAM
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum http://www.techsupportforum.com/forums/f24/adding-ati-radeon-9600pro-agp-slot-issue-128485.html#ixzz1FKivifx5
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't...
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Apr 16, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Nov 21, 2008 | Gigabyte GA-8ST800 Motherboard
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Not getting ATI Radeon 512MB graphics card
Go for :
ATI Radeon X1650 Pro 512MB AGP
ATI Radeon X1600 Pro 512MB AGP
plz rate me if this info is helfull to you... Thanks
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
HP JetDirect EX Plus Print Server Logo
586 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
