Question about Ricoh Office Equipment & Supplies
Paper jam on aficio sp c312 - Ricoh Office Equipment & Supplies
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
El Geek
  • 149 Answers
SOURCE: AFICIO SP C410DN BRAND NEW
There are several steps involved in unpacking your particular color printer.
I'm sure you have the quick start guide which provides very nice photographs of how to remove the packing tape and materials within the printer, but just in case:
http://www.ricoh-usa.com/downloads/manuals/printers/c410dn/manuals/Quick_Installation_Guide.pdf
I hope this helps.
In the odd case that everything is clear and you still get paper jams, take it back and have it replaced before your 30-day or whatever exchange warranty runs out.
Good luck. Keep us informed.
Posted on May 22, 2009
  • 161 Answers
SOURCE: My Ricoh Aficio SP-C210SF Printer jams almost
is the machine new?
check the paper size, check the paper tray -if the paper end fence is loose(the paper should not move around).
try using fresh paper(from a sealed pack)
Posted on Jan 17, 2010
Gunslinger
  • 62 Answers
SOURCE: My Ricoh Aficio 220 has routine paper jams. I
Needs new feed rollers in the paper tray. You can try and clean them but it probably will need replacing.
Posted on Feb 10, 2010
  • 903 Answers
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Posted on Jun 05, 2010
How to remove paper jam from duplex unit
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
Aficio spc242 service call sc543
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
Aug 03, 2014 | Ricoh Aficio SP-C242SF - 21 PPM Flatbed...
Fix paper jam path
Try bringing it to a shop or buying another one on Ebay or Amazon
Apr 10, 2014 | Ricoh Aficio SP 4100N Laser Printer
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
Ricoh SP c221sf Aficio upper misfeed jam? What's that all about? There is no apparent paper misplaced anywhere in the paper path.
I had the same error. In my case one of the two springs in the paper tray was missing (on the floor behind the printer) so there wasn't enough force to push the paper up to the pickup roller. After I installed the spring the error cleared and printing resumed.
May 18, 2010 | Ricoh SP C221SF Aficio Printer
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
My Ricoh Aficio SP-C210SF Printer jams almost every other print i make. What should I do?
is the machine new?
Jan 07, 2010 | Ricoh Aficio SP-C210SF Printer
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
