Riso rz 230aw indicating call service p14 115
Mouse has cut the harness of scanning motor
4 Suggested Answers
  • 17 Answers
SOURCE: i have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Posted on Mar 30, 2010
SOURCE: risograph rz 200ep shows error code d-139
ereur 101
Posted on Apr 27, 2010
  • 55 Answers
SOURCE: the riso rz 390 ui
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Posted on Apr 27, 2011
Engine cuts off while driving
Mate I had trouble with a bad connection in the coil wiring harness, after the motor cut out I'd move the harness around, Maybe you should pull a spark plug out and earth it to the body to see if there's a spark, If it sparks then it's a fuel problem If no spark then it's coil (electrical) /// Also, I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
Mar 08, 2016 | 2008 Dodge Grand Caravan
Need to replace blower fan motor 2006 Chevy Malibu
2004 and up, the old blower motor must be cut out with a utility knife and the new one screws into the opening to the screw holes molded into the plastic housing. It is located under the passenger side dash, you may have a silencer / plastic cover there you have to remove to view it.
  • Remove the passenger's side lower silencer panel.
  • Remove the blower motor wire harness connector.
    Two diagrams show how it goes:
    Cut along the narrow groove where the arrows indicate. Do not cut too deep, only enough to remove motor, as the cup will be re used.
  • Install new motor assembly with three screws, usually provided with new unit. Tighten securely.
  • Atatch wire harness. Test unit. If functioning properly, replace silencer / cover.
  • Jul 22, 2014 | Cars & Trucks
    Printing pdf's, margins are wrong and cut off on top and left.
    Hi
    Choose the correct paper size of your printer for scanning and printer because I believe you select the incorrect paper size and it cut the pdf scanned file.
    Go to printer icon, right click mouse and choose printing preferences and choose the correct paper size. Then go to scanning properties and choose the correct paper size.
    Mar 16, 2011 | HP LaserJet 1022 Printer
    My LG washer keeps displaying LE error and shuts down. What is wrong with it?
    HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
    Nov 20, 2009 | LG WM-2277HW Front Load Washer
    Getting Le error code and washer stops
    HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in thsi case, the motor will need to be replaced.
    Nov 18, 2009 | LG WM-2277HW Front Load Washer
    I own a lg washer le has poped up on dig. screen tub will not spin ...
    HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced, as well as the sensor
    Aug 18, 2009 | LG Washing Machines
    # 1 injector not firing
    Well you need to check the harness to see if it is getting power. You may need to take the plentum off and then unplug the harness and then reinstall the plentum but make sure that you leave the harness out so you have access to it.
    Then you can make a test light or purchase one. Plug the test light into the harness and start the car. This light should flicker, if not you didn't repair the wire properly. Doesn't sound like a fuse being that none of the injectors would work if a fuse blew.
    It could also be that the PCM grounded out when the mouse chewed the wire and needs to be replaced.
    Don't worry about checking the ASD Relay because that would cut off all power to the injectors and coils.
    Apr 22, 2009 | 1999 Dodge Intrepid
    Washing Machine Motor Missing Wire Harness
    Go to www.repairclinic.com and order the complete wire harness and cap.
    Easy place to do business.
    Jan 23, 2008 | Washing Machines
    118 people viewed this question
    k24674
    jasbo
    jasbo
