Question about Canon PIXMA iP4600 Color InkJet Photo Printer
An ink tank can not be recognized of pixma ip 3680
The Machine
  • 788 Answers
SOURCE: won't recognize black ink tank - even when a new one used!!!
Are you using Canon brand ink?
Could be dirty contacts in the carrange behind the cartridge. Clean with the eraser on a pencil.
Posted on Jan 11, 2008
SOURCE: pixma mp500
For iP Series Printers: Holding the paper feed button down for 3-5 seconds will allow you to override the counter. The cartridge will print , however the ink level display may not show.
For MP Series Printers: Holding the STOP/RESET button down for 3-5 seconds will allow you to override the counter. The cartridge will print, however the ink level display may not show.
Posted on Apr 05, 2008
SOURCE: pixma 500 - Ink Tank 'Not Recognized"
carefully remove the tanks from the print head cartridge. use a q-tip lightly soaked in isopropyl alcohol, or use a q-tip paired with an alcohol prep pad from a first aid kit.
gently rub the rubber seating areas for each tank, removing the dried ink from the rubber seat. swab the soaked q-tip, or use the q-tip to gently press the alcohol prep pad into the rubber stopper. use a different spot on the q-tip or pad for each one.
check the print head for ink stains on the black plastic, clean those as well.
Use canned air to dry the stoppers, replace the tanks, and check status. Print a test page and check results.
If you do not print many items, you can avoid the situation by printing a test page every once in a while to keep the contacts clear. Also, run the program to clean the print heads occasionally, and always turn the printer power off at the printer (that seats the tanks down on the stopper, helping to prevent the contact getting plugged by dry ink.
Posted on Apr 07, 2008
ioktay
  • 493 Answers
SOURCE: getting error U043
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Posted on Mar 25, 2010
sunandjoon
  • 125 Answers
SOURCE: my canon PIXMA MP450 all-in-on-printer is showing U059 the following ink cartridge cannot be recognized i tryed to put the old ink tank in but it said the same thing
Basically, there is no solution for your case. This happens especially for Canon product.(called e5 error) Once a cartridge is not recognizable, there is no way, you can use it.
The only way you can do is, replace with brand new one. This is typical Canon problem especially when you refill or re-use your cartridges.
You may see some solution from web such as reset the printer, do somthing to printer software... But non of these methods are working.. Even if there is one, it must be very difficult to do it for individual users.
However, as for a prevention, make sure unplug the power cords before insert or eject the cartridge from printer. In that way, you can at least reuse your cartridges for refill. Hope it helps.
Posted on Dec 14, 2011
Testimonial: "thanks for the help mate will try it :)"
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My printer pixma ip 1600 says ink absorber is full contact service provider. pls. help me what to do. thank you and God Bless.
my printer is canon ip 1700 pixma
i have problem with ink absortion tank is full.
please help me.
thank you.
inaocha
Dec 13, 2008 | Canon PIXMA iP1600 Printer
My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Oct 18, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
386 people viewed this question
old marine
old marine
