Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio WTW6600SBO Top Load Washer off balance
No matter how I distribute the clothes it bangs really bad when spinning? Can we fix it our selfs or do we need a repair man?
  • Gaile Storm Nov 29, 2012
    Yes after it bangs around for a couple seconds it says uL
  • Richard Roth
    Richard Roth Nov 29, 2012
    OK, sounds like one of the suspension rods may be broke. Here is the service manual for that unit.https://docs.google.com/open?id=0ByaSSg1... and here is the rods to order in case you find them bad.http://bit.ly/TuatBS
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Do you get an error code on the display?
Posted on Nov 28, 2012
  • 92 Answers
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Posted on Feb 06, 2009
SOURCE: drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Posted on Jul 15, 2008
SOURCE: Washer Spins But Clothes Still Wet
I replaced the Clutch Assembly.
Posted on Dec 11, 2008
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
  • 327 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load Washer- when
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer for a quote and then draw your own conclusions as to whether it's worth it.
Thanks
Posted on May 23, 2010
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does my washer gets off balance during the spin cycle and how to repair it
A QUICK FIX IS TO OPEN THE DOOR TO STOP WASHER, THEN RE-DISTRIBUTE THE LOAD SO IT BALANCES OUT IN THE SPIN CYCLE. OR, REMOVE SOME OF THE CLOTHES, IT COULD HAVE TO MANY IN IT.
Feb 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
341 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
