Samsung washing machine wa82v4g water not feeding from inlet
Top load model wa82v4g 6.2 kgs
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
  • 1531 Answers
SOURCE: Samsung SW65ASP2 top load washing machine only
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Posted on Jan 31, 2010
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
Water is not stop automatic
Do you mean: The water continues to run into the drum? If so you need an appliance engineer to check out the incoming water solenoid valve.
Nov 06, 2014 | Washing Machines
Modelno wa82v4g water is not stop automatic so what to do
Check the hose of the water sensor level or water inlet valve
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
How to operate samsung wa82v4g washing machine. Water does not stay in washer at all.
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 25, 2010 | Washing Machines
Samsung SW65ASP2 top load washing machine only lets water in slowly.
Jan 31, 2010 | Samsung SW62ASP Top Load Washer
80 Series Top Load\ Water Feed
There may be a screen in the inlet pipe where it joins the back of the machine. Also check that the inlet pipe is clear and running water correctly before connecting it back on the machine. If this is OK you may have an issue with the inlet valve not opening fully. This is quite a common issue and will need the inlet valve repalcing.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Purchase of washing machine
well...the hole less drum has more concentrated spin/wash water solubility. The hole drum has a more effective rinse release cycle. The holeless drums are usually used for higher weight loads, since the water penetration on those can be critical. Water capacity and usage are key to this choice. It all depends on the availability of clean water in your district.
Feb 10, 2008 | Washing Machines
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
