Question about Air Tools & Compressors
Bostitch 16 guage straight nailer jambs every nail
I am using the right guage nails. In fact they are the ones that came in the case with the gun. 2". I have the proper amount of air pressure. I have fired less than 100 nails through this gun. Whats the problem? Is it just that big of a piece of junk?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Tip of your piston may be damaged... or the feeder system is not bringing the nail fully into position. You may have to file the rail to correct any damage that a jam may have caused
Posted on Dec 09, 2012
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
get a senco
Posted on Mar 11, 2009
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
  • 24 Answers
SOURCE: NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Posted on Jul 07, 2009
  • 12 Answers
SOURCE: My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Posted on Oct 04, 2009
Bostitch troubleshooting
Are you using 18 gauge or 16 gauge nails?
Aug 17, 2014 | Stanley Bostitch FN16250K - 2 16 - Gauge...
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
Air leak out of driver unit
In most nail guns the piston o-ring is the problem. Inspect the o-ring for any signs of damage and in some cases the o-ring has a manufacturer defect.
Mar 23, 2012 | Stanley Bostitch SB1664FN 16 Gauge...
How to load bostitch sb1664fn nail gun
Push on the button on the rear of the tool to open the magazine. Pull the magazine back. Load nails in the stationary part of the magazine with the heads of the nails at the top of the magazine. Push the sliding section of the magazine back into place making sure it latches.
Jul 04, 2011 | Stanley Bostitch FN16250K - 2 16 - Gauge...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Nailer fires first nail successfully but next nail jams. It appears the part that retracts after each nail is ejected does not retract all the way so the next pack does not load properly. Have cleaned and...
first make sure you are using the right guage nails. then I would look at the condition of the driver to make sure not bent, also look for a broken nail in the magazine area which will also cause this, lastly does the piston/driver "fall" in the cylinder?? there should be some resistance against the o ring, if not then it could also cause your described problem,
Dec 21, 2010 | Stanley Bostitch SB1664FN 16 Gauge...
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
My nail gun will not shoot nails any suggestions?
could be several problems, are you using the right guage nails, is there a nail jammed in the nose assembly, is the driver bent or broken, I would look for a jammed nail first and if none then I would remove the cap and check the condition of the cylinder and piston. they have a bad habit of breaking the driver blade loose from the piston
Nov 26, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Air Tools & Compressors Logo
56 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
