Question about Car Audio & Video
Clarion cz 202e - display setting
Can anyone advise how to alter the default display setting where the unit simply scrolls through the various features? I would really appreciate keeping it to the track detail if at all possible. Many thanks
4 Suggested Answers
  • 3 Answers
SOURCE: clarion head unit// i need to find a user manual
What features do you need? You can mute by pushing the 4-way button in.(is it called a joystick??).
Posted on May 01, 2009
etirbynnor
  • 655 Answers
SOURCE: clarion cz 209 problem
Hello sashunter,
The most likely cause for the problem is that either the power antenna lead or the amp remote turn-on lead has shorted to ground somewhere behind the dash.
Pull the unit back out and make sure that the ends of all of the unused leads are completely covered.
The best way is to use an insulated crimp-on closed-end connector on the end or each unused wire. Heat shrink tubing is also OK. Fold the end of the wire back into a "U" shape and shrink the tubing over the "U" overlapping it about 1/4" on both ends. You can use electricians tape as a last resort, but it's messy if you ever need to remove it and sometimes it just comes off by itself.
Hope this helps.
Posted on May 11, 2009
SOURCE: how install clarion cz 309
How do you get a clarion CZ309 out of amp_gnd mode
Posted on Apr 25, 2011
My clarion vz401 is stuck on mute and I don't have a remote how do I fix it
I assume you do not have the brown wire connected to a ground as that will put the unit on mute. The only option I know of is to either reset the unit via the on screen display or disconnect power for a minute or two. Here is a link to crutchfield...scroll down and click on owners manual and you can download it. It appears that this is one of those units that you really need the remote for to access some of the features.
http://www.crutchfield.com/S-uMFEqoUicsa/p_020VZ401/Clarion-VZ401.html
Jul 26, 2016 | Clarion Car Audio & Video
Clarion cz-202a filr read issue
Make sure you are saving in a supported file format.
Jul 18, 2016 | Clarion Cz202 Cd/usb/mp3/wma/aac Receiver...
Fogot my passcode
Hi Rondal,
You can restore the default factory settings for your device by pressing the left soft key for Menu and then selecting Settings > Phone > Security. Enter your Phone Only Security Code (default is the last four digits of your phone number) and select Reset Settings. Read the information displayed and scroll down to select Yes and press the OK key. Using the Reset Settings feature will not delete your personal information; it will restore only settings like default ringtone, keypad tones, and display settings.
Cheers
Apr 13, 2014 | Samsung Gusto 2 SCH-U365 Verizon
BT Aura 1500 Quad telephone - calls list freezing
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Jan 15, 2013 | Lands Phones
On the SAMSUNG SGH-ZV40 how can i change the ring tones. can i get a step by step guide as my screen has broken
Hi Lilfranza,
Menu structure is: Menu/Settings/Profiles/Normal Profile/Options/Incoming Call/Voice Call Ringtone see details below
Sound Settings
You can customize various sound settings.
1. When the Idle screen displays, press the Menu soft key.
2. Select Settings and press the Select soft key or the Cingular icon key.
3. Select Profiles and press the Select soft key or the Cingular icon key. Use the Down
Navigation key to scroll through the following list of available options:
Normal Profile
To access the available options for this calling profile, press the Options soft key.
Highlight Edit and press the Select soft key or the Cingular icon key. Use the Left and Right
Navigation keys to move between the various tabs. This menu allows you to alter the
audio settings for the following categories:
• Incoming Call: allows you to edit the properties for audio alert used for incoming
phone calls.
-_ Voice Call Ringtone: allows you to select a ringtone from your My Stuff (Phone)
folder which contains not only the default phone ringtones, but also any new
ringtones which have been downloaded from the Internet.
Mar 15, 2011 | Samsung SGH-ZV40 Cellular Phone
I need to change my region code to Europe How do i do that?
The device manufacturer predetermines the available setting from which adjustments are achievable elsewhere from factory. First, once a device is acquired from the market, an initial installation has default settings that are capable of alterations with conditions. Products manufacturer for the American market would usually have for regional settings the fifty main land states to include territories at which availability become possible. For example, devices may have for regional settings east coast, west coast, mid western states, and southern states as choice settings capable of alterations. However, device intended for the American market may least have regional alteration feature capabilities. The default regional settings may have been the devices only available settings. Alternately, device may simply disallow settings like with those without any regional adjustment features. Exploring through the device menu buttons should make available any manufacturers embedded setting capable of manufacturer's alterations. If any settings are found on the device, refer to the user guide for step by step instructions on achieving alterations.
Jan 21, 2011 | Canon MP640 All-In-One InkJet Printer
Audio goes off by itself & have to turn tv off then on to get audio back why
Appears that the audio volume mute functionalities have been altered to display momentarily shortly to go on silent mode. The TV settings have to be realtered to acquire default audio or volume features during functionality or operations. The type of device connected to the TV mayy simply operate mometorarily shortly least producing sound past several moments. Ascertain the devices with which the TV is acquiring audio or videography. Disconnecting to resestablish upon reconection should perform default functionalities. Refer to user guides for diagnostic performance of TV during operations. Consul technical experts thereafter. Good luck
Jan 08, 2011 | Vizio 42 in. LCD TV
My screen keeps freezing on its way to standby, i keep having to manually shutdown my machine. I appreciate any suggestions.
in this case , the problem is in Hard disc.In my experience the new hard disc also giving the same trouble like your problem.first you shoud install the fresh os.it might be solved your problem.
Dec 02, 2010 | Computers & Internet
Line 1 stopped ringing. The light lights up but does not make a sound. This is the 2nd unit we have had to do this
To program the ringing on the cordless handsets:
Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press .
3 Scroll to “Ringer volume” by pressing
L The current volume is displayed.
4 Press {V} or {^} to set the volume.
L Each time you press {V} or {^}, the
volume will alter and the chosen volume
will sound.
L To turn the ringer off, press {V}
repeatedly until “Ringer off?” is
displayed.
5 Press .
L Confirmation tone is heard.
Sep 13, 2010 | Panasonic KX-TG4500 Phone
HOW DO YOU SET THE CLOCK ?PIONEER DEH-P49001B CAR FM/AM/CD/MP3
See instructions below:
Initial Settings
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press FUNCTION and hold until function
name appears in the display.
3 Press FUNCTION repeatedly to switch
between the following settings:
CALENDAR (date and clock)—
WARNING TONE (warning tone)—AUX1 (auxiliary
input1)—AUX2 (auxiliary input2)—
DIMMER (dimmer)—S/W CONTROL (rear
output and subwoofer controller)—
DEMONSTRATION (feature demo)—
EVER-SCROLL (ever scroll)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down FUNCTION until the unit turns off.
Setting the date and clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment you
wish to set.
Day—Month—Year—Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Press a or b to set the date and clock.
Pressing a will increase the value of the selected
segment. Pressing b will decrease the
value of the selected segment.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/415128381DEHP4900IBOperationManual0216.pdf
Aug 20, 2010 | Pioneer DEH-P2900MP CD Receiver...
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
