I have a Goodman GMH80904BN heater that only stays on for few seconds and then kicks off
When I turn on the thermostat it kicks the heater on for only a few minutes and then the system shuts right back off. What do I need to do to fix it?
SOURCE: heater won't stay on
This product does indeed have a problem with the safety switch, that is only supposed to kick in when the unit is turned over. I had a total of 3 units sent to me from Kaz. Each time the unit would work for a short time, then slowly begin to turn off and on. I finally decided to take the unit apart and look for any obvious problems. There is a weighted swivel that will raise a contact point to turn the unit off in an emergency. The contact points would spark off and on, depositing a black carbon on them until they would no longer allow power to pass through. I cleaned the contacts with a fine finger nail file and bent one of the contact arms inward to make better tension between the contacts. This allowed the unit to stay on for longer periods of time. But even with the thermo-stat turned all the way up, the unit does not stay on long enough to heat the room. In effect, what happens is the contacts will continue to ark, putting black deposits on the contacts until you're back to square one. Apparently the unit also has a thermo-stat related problem. I'm sending the unit back again (they only made me send the power cord last time), but will insist on a different model this time. Good Luck
Posted on Feb 24, 2008
  • 14 Answers
SOURCE: The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Posted on Feb 28, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
SOURCE: oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Posted on Dec 18, 2008
SOURCE: won't stay on
mso 9]> Normal 0 mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> Warning this will disable the tip over sensor, Unit will not automatically turn off when knocked over!!
I had the same problem with the "F" appearing and the unit turning off. I read a similar post about the hz-709, that talks of removing the "tip over sensor". To remove the sensor, "two little black boxes on one chip, that rattles like there is a ball bearing in each box."
Remove two small screws on the bottom of the heater then remove two small screws on the top of the heater "top screws are under a small cap that can be popped of with a flat head screwdriver."
Inside long panel front Unplug three wires, White Brown Blue "remember where they where plugged in, so you can plug then back in later."
Inside long panel front there is a silver panel with eight screws on it only the, only the four "corner" screws have to be removed to remove silver panel.
remove silver panel then remove remaining 4 screws, Now remove front control from long panel front, there are 6 screws only have to remove the four inner screws, Open white box, slip large chip off three prongs,
there are two small blue wires connecting to the two small black boxes from the beginning of this post, cut wire from box, twist or solder together, and tape with electrical tape.
"You have just removed/disable the tip over sensor, Unit will not turn off when knocked over!!"
Reverse steps reassemble the unit and enjoy.
Posted on Dec 23, 2008
Code 1 on a goodman furnace. Changed filter, reset thermostat, hit the breaker for reset and still the temp is dropping and the unit is not kicking from the thermostat. Thermostat is only a year old.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
Feb 02, 2014 | Goodman Heating & Cooling
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
Goodman units blower kicks off and on on its on while ac is running
Check air filter is clean ans also check and see if flame sencor is clean
Jun 20, 2012 | Goodman Heating & Cooling
Goodman GMP 100-5 Rev B Serial # 9902602550 The status light stays illuminated. It isn't blinking. I believe my igniter went bad. When I turn on my heat on the system, The exhaust fan kicks on,...
Hello, the first thing is check the igniter for any crack or white spots on it, also, if you have a multimeter check the resistance of the igniter, should be between 40-90 ohms. You can purchase a igniter at any Heating and Cooling supply store.
Mar 11, 2011 | Goodman GMS90703BXA Heater
I have 2 goodman heating systems. one for upstairs and one for downstairs. The downstairs works great. With the same temp settings on the upstairs, The blower kicks on and you hear the the flame kick on...
i have seen this just the other day customer called and there thermostat would not maintain temp... changed batteries and after five mins did it again... couple of things need to make sure you have fresh batteries if it takes them in thermostat. also try overriding program by pressing the hold button and set where you desire see if it works then... if it still fails to maintain you need to make sure the unit is not running when it is suppose to be off... if the fan is running and the thermostat is not calling for heat or cool then it is possible the flame sensor on the heater is bad or needs to be cleaned... to be honest based on what you are saying sounds like you got two different items going on....
a sure way to test if your mechanical inclined is take the t-stat apart jump the r terminal to the w terminal go to unit and unplug for 10 seconds and plug back in if everything fires up and stays going you 100% have a thermostat issue...
Dec 31, 2010 | Goodman Heating & Cooling
Red led blinking three times, furnace kicks on, runs about 10 seconds gas flow stops and it recycles, heats up runs for ten seconds
check flame sencor is clean or loose connection , or it could be the pressure switch try jumping it out and see if it stays on ,
Nov 10, 2010 | Goodman GMS90703BXA Heater
GMP075-3 looks good but shuts off after 10 seconds
Replace the thermostat control sounds like the control contacts are not holding since you cleaned the bulb and the igniter is working the only other issue is the thermal buld being bad, shut it off heat the bulb for three minuts then quickly turn it back on and see if it stays on longer if it does the bulb is the problem.
Oct 07, 2009 | Goodman GMS90703BXA Heater
Heater not staying lit
my furnace pilot light is on but the burners will go off when we put the thermostat on auto. if we keep the fan on the burners will light but turn off the fan and and the burners go off
Mar 01, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
