Question about Aurora Electronics AS890C Shredder
Where can I obtain parts for an Aurora AS890C shredder?
Paper sensor shaft has broken and needs to be replaced. Where can I obtain a replacement?
  • 537 Answers
SOURCE: I just bought my shredder 3 weeks ago and
Did you open up the shredder or remove it from the basket? Look and see if the switch is in the right place and is not being blocked.
If you didn't mess with the switch and just cleared the jam, then take it back to where you bought it for a replacement
Posted on Apr 17, 2009
FixinFax
  • 3085 Answers
SOURCE: Should I be oiling my AS890c shredder, it still
Yes, once a month with 3-in-1 oil or Marvel Oil.
Posted on Oct 21, 2009
  • 22 Answers
SOURCE: I have an Aurora as662c paper shredder, I have a
There are 5 screws that you need to remove, 1 of them is hidden beneath a white sticker that says void warranty if removed.
Posted on Sep 08, 2010
HansPP
  • 2510 Answers
SOURCE: My AS101bCD Aurora shredder will
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
Posted on Jan 26, 2011
  • 12 Answers
SOURCE: I have an Aurora Shredder
Check safety and detection switches. 1. Safety is on the bottom and left or right side of shredder unit inside a narrow gap. On the bucket's wall there is a natch witch should go into the gap, when you put shredder correctly. Check if switch and natch are on the same side. Simple turning around will solve problem. 2. Check a detection switch. It is located in the middle, inside of gap. This switch engages and turns motor on when you put paper into shredder. In other words sheets of paper should push the switch first before touching shredding rolls. If you have digged out that paper from the top side, chances are you have broken that switch.
Posted on Feb 12, 2011
How do I remove the shredder head case of an Aurora AS890C? I have removed the 6 screws (it's unplugged), but it still won't come apart. It quit working, so I don't know if it's jammed or...
There are 7 screws. You missed the one hidden under the small silver label.
Once you take it apart, don't waste your time calling Aurora as you voided your warranty and ability to get help from them. That happened to me.
May 12, 2011 | Aurora Electronics AS890C Shredder
Got jammed. It will now run in reverse but not in shred mode.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 07, 2011 | Aurora Electronics AS890C Shredder
The shredder will not accept paper. It works in reverse, but when I turn it back to auto it runs a short time and goes off..
Feb 22, 2011 | Aurora Electronics AS890C Shredder
If I put the document in straight it won't shred. I can get it to shred if I insert it on the left hand side - there seems to be some kind of jam on the right hand side.
Unplug it first. If you are certain that there is a jam, take the top off and flip it upside down. Use a pencil or other object that is NOT YOUR HAND and try to remove some of the paper jammed up. It is also possible that there is only a sensor on the left hand side. If this is the case there isn't much that you can do. Hope this helps and tell me how it works out!
Oct 07, 2010 | Aurora Electronics AS890C Shredder
My shredder makes a thumpping noise then stop. Inreverse it does the same thing. My model is Aurora AS701X-MS The motor runs but it does'nt shred the paper unless you shake the paper then it stops.
It sounds like one of the drive gears has broken. I have contacted this manufacturer before and was told that they do not make replacement parts for their machines. If it is less than a year old, they will replace the unit but that is about all they will do.
Jun 20, 2010 | Aurora Electronics (AS701X) Shredder
Cannot get it shred forward or reverse. Is there a reset or fuse Paper shredder
probably has broken gears. Aurora does not produce replacement parts for any of their machines. Actually made by Royal and they don't make parts either so don't buy either brand.I guess Fellows is about the best brand or GBC.
Nov 13, 2009 | Memorex Paper Shredder
Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Feb 19, 2008 | Office Equipment & Supplies
Aurora Electronics AS890C Shredder Logo
114 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
