Honeywell T8131C thromostat display has faded almost completely. Any suggestions other than "get a new one"?
2 Suggested Answers
SOURCE: I have a Honeywell T8131C
I tried all the tricks mentioned previously to no avail.
These are the steps I performed to get it to work:
1. Remove batteries and make sure the battery contacts inside the unit are clean.
2. Disconnect all the wires from the back of the unit. Be careful not let any of the bare wire ends to come in contact with each other. Make sure you mark the wires or verify that the color code matches the markings on the rear cover:
W=White wire;
Y=Yellow wire;
G=Green wire;
R=Red wire (low voltage DC); and
C=Common (wire color varies)
3. Leave the unit disconnected with batteries removed for about an hour to make sure all the memory drains. I waited an hour, but it may not require that much time.
4. Install the batteries in the correct positions per the instructions. The unit should perform a power up display test, then the display will flash the time and temperature.
5. Set the clock and the display will stop flashing.
6. Slide the switch to cool and/or heat and program the desired weekday/weekend settings.
7. Slide the switch back to off once all weekday/weekend settings are made.
8. Reconnect the wires that were removed in step 2.
9. System should be operational at this time.
Posted on Apr 22, 2009
I have a honeywell rth110b thermo and the other day I noticed that the display was fading and it looked like the battery icon was showing so I changed the batteries and now the display is completely blank...
The manual does not have troubleshooting steps.
Check the battery polarity, and clean points of connection.
Otherwise honeywell.com has customer care number
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2017 | Water Heaters
How to reset thermostat
as it is a honeywell product and the new second one didn't work it is not for fixya site to fix but as the new part is still under warranty then it is up to honeywell agents to come and fix under warranty
if push comes to shove talk legal,action as it is the company's responsibility to fix faults of new products under warranty
It was not even up to you to buy a new part as it should have been replaced free
May 28, 2017 | Water Heaters
Just went to my thermostat & pressed the temp button. It made a fizzing sound for a few seconds and he display disappeared completely. Have changed the batteries but yhe display is still blank. Is it...
Thermostat is bad. Relace the thermostat. I suggest having a professional replace the thermostat as there are many ways to install incorrectly and lead to expensive service call to repair.
Sep 01, 2011 | Honeywell Programmable Thermostat Heater
I changed the batteries of the Honeywell thermostat and on the screen it still shows low battery.
Hello my name is Heath it will be my pleasure to assist you. Take the new batteries out and let the display go completely blank then reinstall the new batteries and the lo batt light should go off.
Nov 08, 2010 | Honeywell Heating & Cooling
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Rth230b honeywell display screen faint
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Feb 04, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell T8131C programmable thermostat. Our power went out yesterday, and now the "Bat Lo" won't go away. We replaced the batteries, but the "Bat Lo" indicator stayed on...
W=White wire;
Y=Yellow wire;
G=Green wire;
May 29, 2008 | Heating & Cooling
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
