Question about Brother SE-270D Computerized Sewing Machine
Bobbin trouble the bobbin has to be taken out & put back in after each thread change
  • Brother Master
  • 7,365 Answers
Try a different bobbin and see if that helps
also there could be something wrong with the hook and hook race
those parts may need to be checked
Posted on Nov 28, 2012
Testimonial: "I was actually the bobbin case. Your suggestion was very helpful. Thanks again."
  • Amanda Nov 28, 2012
    thanks for the solution suggestion Debbi. I have no repair shop with 50 miles of here. I guess I need a repair manual.
I am having trouble getting my singer 6199 sewing machine to sew. The top thread will not pick up bot thread. I tried changing needle, changing bobbin, rewinding bobbin, rethreading machine & bobbin,...
did you get the needle in correctly--all the way up into the needle holder
& the flat side of the needle goes to the back of the machine
also after you check the needle & it's in correctly it's very possible that the machine is out of time & a sewing machine repair technican would have to retime the machine
Mar 01, 2012 | Singer Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
My mom has the 8050 and the bottom thread when she sews is knotting. She did the trouble shooting from the book and no change. She has only had the machine for four months. Wondering if you have any...
have you try using a different bobbin & thread. make sure the bobbin wound & is inserted correctly
check to make sure the top thread has not come off the thread take up lever
has a new needle been put in?
make sure there are no burrs on the needle plate or bobbin itself or bobbin case
let me know if any of these suggestions help machine work correctly or not
Aug 26, 2011 | Janome Sewing Machines
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
Sew Cute SC20 Mechanical Sewing Machine: how to thread sew cute machine ...
Place the origin bobbin thread so the thread is coming up (clockwise) extend to the thread tention, to the top thread holder, then down through the arm and then through the bottom thread holder, through the square thread guide above the needle, then through the needle, front to back. Check out a picture on ebay or amazon. That could help you visualize it.
If you are having trouble with the thread breaking, try changing the thread on the bobbins. The thread that comes with the machine is poor quality and jams & breaks. If you still have trouble, and might suspect the needle is dull or bent. Change it, it makes a difference. I had the thread problem with the machine right out of the box. Changed it and it works great!
May 17, 2010 | White Sewing Sew Cute SC20 Mechanical...
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
153 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
