My xe-a23s cash register has no power
Its not working when i put on it has no power
  • 7,627 Answers
Wrong category
Posted on Nov 29, 2012
flexion1
  • 737 Answers
SOURCE: how do you reset sharp xe-a302 cash register to factory defaults
Hi.
I would not recommend doing this unless you are certain that it is the cause. I have never had memory corruption in this series before, so I would strongly suggest it is being caused by another factor such as spillage in the keyboard.
Can you tell me exactly which buttons are showing the problem and what happens when you press them. Can you still make sales with the product buttons?
Mark
Posted on Nov 29, 2008
  • 59 Answers
SOURCE: I need to program an XE-A102 cash register for sales tax
Here is a PDF manual that tells you how to do this.
www.sharpusa.com/files/cas_man_XEA102.pdf
Hope this helps.
Posted on Mar 01, 2009
greg_margo
  • 1959 Answers
SOURCE: Tax rate on sharp xe-a102
To change/program the tax rate, use the following procedure:
  1. Turn key to Z/PGM position
  2. Press 8
  3. Press #/ST
  4. Press A
  5. Press #/ST
  6. Press 2 (Auto Tax)
  7. Press #/ST
  8. Press 097500 (9.75%)
  9. Press #/ST
  10. Return key to normal mode
This procedure should program your tax rate at 9.75%
  1. Press #/ST
Posted on Jul 28, 2009
  • 22 Answers
SOURCE: how do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
Posted on Sep 10, 2009
jackcity
  • 33 Answers
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
Posted on Sep 15, 2009
Put in fuel pump and have no power has power at fuse box
When are you checking for power? When you turn the key on, the main relay energizes the fuel pump for 2 seconds only, then shuts off the pump until you start cranking.
Nov 24, 2014 | 1997 Acura TL Series
Three lights work out of seven after I reinstalled them after cement walkway was put in
I don't know if wire is damaged, connections are bad, or bulbs burned out.
Best to test each.
Copy following link for general troubleshoot resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 07, 2012 | Intermatic Ml121rt Malibu 121-watt Power...
Horns don't work when power put to them with a
If you did apply power directly to the horn and they don't repsond or just "buzz" then you need new horns.
Jan 27, 2012 | 1991 Mercedes-Benz Mercedes Benz 500 Class
Power steering in hyundai xg350 doesn't work. Put
power steering need bleeding if your reservoir was dry when you added fluid if.fluid was okay not too low.your power steering pump could be faulty.the cold weather will effect it.
Dec 13, 2009 | 2002 Hyundai XG350
Should i put power steering fluid or automatic transmission fluid in the power steering pump
THE FLUID IS PUT INSIDE THE BONUT JUST OPEN IT AND SEE TERE IS A SPACE TO PUT FLUID FOR STERRING()AND PLS VOTE ME
Nov 22, 2009 | 2003 Kia Optima
Wont work on battery power
hi is it not powering up at all? i have the same problem here!
if you found the answer, please put it over here!
Dec 17, 2008 | Canon MV630i Mini DV Digital Camcorder
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
