Question about Texas Instruments TI-5660 Calculator
I need a parts diagram for the TI-5660...black bar came off and I don't know where it goes
I installed a new starter solenoid in my ranch King "93" riding lawn mower Model # 133K6796205 MFG code 1K192840178. I followed the diagram in my manual but when I turn the key nothing happens. ...
hi there wolves 52
here is website for parts
http://www.ereplacementparts.com/mtd-133k679g205-1993-lawn-tractor-parts-c-20039_20060_63114.html
go to page c then download wiring diagram
it should vave main switch connection on it ( may need to enlarge )
basically switch markings
G= ground ( usually black )
L = lights/ carb solenoid if it has one
M = magnetron kill wire ( usually black )
S = starter solenoid ( white ,usually goes through a interloc but could be orange check your diagram )
B = battery this wire will come from the the battery itself directly or from the hot post of the starter solenoid )
suspect 5 terminal 3 position switch
connections for off G + M
connection for on/ run B + L
connection for start B+ L + S
hope this helps , if not get back to try help further
cheers pauly46
dont forget the thumbs rating
Jun 05, 2011 | Garden
My ti-84 calculator wont react to anything and it says garbage collecting. i think the bar on the side should move and its not moving and its been like this for several weeks. i did download a whole pile...
I remember this happening once to my TI-83. I know it's a different calculator. But it happened frequently. Without completely reconfiguring the calculator, you can remove the batteries whenever you see the message and when you start it up again, it should be okay. It may continue to display this message once in a while. I used to just remove the batteries. I don't know if it will work on your TI-84 the way it worked on my TI-83, but I hope this helped!
Please rate my solution!
- Frankie
May 05, 2011 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-5660 Calculator Logo
51 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
