Question about Kyocera FS-3900DN Laser Printer
Error f040 how do i solve it - Kyocera FS-3900DN Laser Printer
    New Friend:
  • 56 Answers
Try to upgrade the engine and main firmware to the latest versions. If this procedure does not work, then you must replace the engine pwb.
Posted on Dec 01, 2012
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I have a kyocera fs-3830 F040 Failed what is the problem?
This error means - Communication error - Communication between the engine board and the main board is failed. IF there are no loose connections then yo most likely have a bad main board which will need to be replaced.
Dec 21, 2010 | Kyocera Mita FS 9500DN Laser Printer
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
Kyocera fs 9530 - f040 error
this error came because of the Defective harness between engine PWB and main PWB or improper connector insertion. open both board and re fix it and check ....... please mention your correct printer model in next comment so we will give you idea how to open the boards ....... restart your printer and check it ...........
Main - Engine controller PWBs communication
error
• The communication breakdown occurred
between main controller PWB
and engine controller PWB during 30
seconds.
cause
Defective engine controller PWB........Defective main controller PWB.
solution
Replace the engine controller PWB
Replace the main controller PWB
Dec 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
Jan 03, 2008 | Kyocera Mita FS-3830N Laser Printer
Printer not responding after a jam
http://files.oce.com/nl/download/printers/PP20D%20Operation%20Guide%20(Engelstalig).pdf Here is the link to the pdf manual for the printer. They show some light sequences and mention something about the old toner cartridge may need to be emptied/replaced. I'll let you know if I think of anything else. Tim
Jan 29, 2007 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS-3900DN Laser Printer Logo
454 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
