Question about Teklynx International Company Label Matrix (lm7ppkk) for PC
I forgot user id and password to get into label matrix. How do I fix this?
I accidentally set up a user id and password for the Label Matrix program instead of just setting up a password for the specific label itself. Therefore, since I can't remember what the User ID is, I have no way of getting into the program. Is there a way to get into Label Matrix now?
How to enter matrix to the calculator
Turn calculator ON
Press the Mode key.
Select the Matrix Option
Select the name of the Matrix: MatA , MatB, or MatC
Choose the dimensions of the matrix (3X3, 3X2, ..2X1)
Calculator displays a template (empty spaces where you enter the matrix coefficients.
Type = after each element.
Press AC to exit the matrix editor.
Now you are ready to do (legal) operation on the matrix.
Available opeartions are found under SHIFT 4: Matrix.
To enter a matrix label on the command line (MatA, MatB, or MatC) you press SHIFT;4 (MATRIX), and select the label by pressing the relevant number in the list of options
Jan 24, 2012 | Casio FX-115ES Scientific Calculator
How to enter the matrix
Open the ScratchPad/calculator application then press MENU.
Use arrows to highlight Matrix/Vector or just press 7
Press 1 Create then 1:Matrix
Choose/Enter the dimensions.
Highlight the OK button and press ENTER. The screen displays a template of your matrix.
Enter matrix coefficients.
If you plan on doing something with the matrix, you have to give it a label (name).
Aug 28, 2011 | Texas Instruments TI-Nspire Graphic...
I forgot my user id and password of my 7.2 tally data. How can i open it?
I forget my tally Username & Password of too many data folders, Kindly advise accordingly
Jan 18, 2011 | Tally T2245 Matrix Printer
The printer adds an extra line space at the end of every label I print, by the 4th label they aren't usable
You could fix this in the printer, but faster and easier to alter your program's printing function. Check that you are using the correct form template, and either delete one line from your data, The program may be issuing a line feed, or modify the form dimentions.
print on blank paper until you get it dialed in. Hold up to light and lay labels over or under it to see alignment
Oct 15, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
105SL is taking template from Label Matrix and stretches it so the data matrix part is unreadable when scanned. How do I make it take an existing template and retain the print size, font and 2D?
Check to make sure you have a 105SL printer driver. Also check to see if you have chosen ZPL for the language as well as the proper resolution (203, 300 and 600 dpi).
Sep 28, 2010 | Zebra 105SL Thermal Label Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
Label printed too long
¿Que software de diseño estas utilizando (label matrix, codesoft, bartender) ? Estos programas tienen sus propios drivers, pero cuando utilizas otro driver puede haber conflictos con los tamaños de las etiquetas. Verifica que las dimensiones de la etiqueta en el driver y en el programa sean los mismos y que los margenes sean los correctos. What design software are using (label matrix, Codesoft, bartender)? These programs have their own drivers, but when you use another driver may have conflicts with the size of the labels. Verify that the dimensions of the label on the driver and the program are the same and that the margins are correct.
Jan 19, 2009 | Datamax I-4208 Thermal Label Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Apr 13, 2007 | SATO CL408e Thermal Printer
Teklynx International Company Label Matrix (lm7ppkk) for PC Logo
42 people viewed this question
Top Teklynx International Company Computers & Internet Experts
David Payne
David Payne
Are you a Teklynx International Company Computer and Internet Expert? Answer questions, earn points and help others
