Question about AEG Washing Machines
Lye pump 60Hz for AEG Oeko Lavamat 981
Hello, I am from Germany and I want to use my AEG Oeko Lavamat 981 (E-No.:068 940 767). The problem is that the 50Hz lye pump (AEG no.: 645333010) doesn't work. I am looking for a 60Hz lye pump. Do you have a 60Hz pump for this washing machine? You can call me +1 248 802 8243
Best Regards
Mark
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG Oko-lavamat 538 manual
www.manualshark.org/manualshark/files/5/pdf_10471.pdf
Posted on Dec 10, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
SOURCE: how do i reset a aeg oko lavamat 72620 washing
how to make reset to AEG OKO lavamat 61600
Posted on Nov 14, 2010
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Require a user manual for a LAVAMAT 1000 to download
Hello I need to number kushintës Lavalogic AEG 1600 washing machine
Feb 07, 2011 | AEG Lavamat Lavalogic 1600 Front Load...
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
