Question about Maytag Atlantis MAV6000 Top Load Washer
Loud squeal WHEN THE WASHER SPINS, IT STOPS WITH A LOUD SCREACH.  IT IS AN ATLANTIS MODEL ( MAV7200AWW ).  IT SEEMS TO WORK GREAT OTHER THAN THAT.
  • 1 more comment
  • flyingjohn Jan 12, 2009
    I think it's the brake at the end of the cycle. Had a similar problem with an earlier Maytag. It is a great washer other than that.
  • maritzburger Feb 15, 2009
    I have model MAV6200 AWW and the exact same problem. Hope it is not the gears or something major.
  • chinadoll94 Feb 17, 2009
    We have the exact same problem. We were also told possible problem with transmission and none to be found! Washer 2003 and no children at home here! Washers obviously not made to last long. Older washers had a better lifespan. SO MUCH FOR MAYTAG!!!
Just found a suggested solution to this problem and it is the same suggestion I received from a colleague who worked on repairs to the these types of appliances. Have not tried it yet, but will and then post a follow up. Check out the solution at www.applianceaid.com. It is apparently the brake that stops the tub at the end of the cyclehat causes this squealing.
Good luck
Posted on Feb 15, 2009
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Makes loud squeal noise when stoping to change cycles
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Jan 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Whirlpool Ultimate care II loud squeal
The drive belt may be loose, and slips on the pullys as it goes into higher gear. It may need replacing.
Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
346 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
