Question about Acer Emachines E525 E625 E627 E630 E725 Palmrest
Need a recover disk - Acer Emachines E525 E625 E627 E630 E725 Palmrest
  • Acer Master
  • 2,878 Answers
Https://store.acer.com/store?Action=DisplayDataValidationServicePage&Env=BASE&Locale=en_US&SiteID=acerna
Posted on Nov 29, 2012
Creatacard address book. new computer cannot install disks?
Recover you'lap by press assist click then choose f11to start rcovery.after that you'r system will renewing.but after that you should check if you'r disk work or not.
Dec 11, 2014 | Computers & Internet
Tip
How to Recover Data From a Disk Encrypted by Bitlocker. Data Recovery.
Today we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where BitLocker stores important data, that happens due to unexpected system shutdown), inability to load OS or BitLocker recovery console, and other similar errors that prevent normal opening of the encrypted disk. The described problems may affect both system disk,portable external drive or USB drive.
In order to recover data we will use the utility Repair-bde (BitLocker Repair Tool), a command prompt utility which appeared back in Windows 7 / 2008 R2. This utility is used for access and recovery of encrypted data in a damaged disk encrypted by BitLocker.
Warning. This procedure should be applied after all the others have failed, and it was impossible to unlock the encrypted disk in a standard way by using a Bitlocker password or recovery key.
Requirements for data recovery from a BitLocker volume
To recover data from a disk encrypted by BitLocker you need to have at least one of the following Bitlocker defense elements:
  • BitLocker recovery password;
  • Recovery key;
  • System startup key (Startup key - .bek).
Data will be recovered to a separate disk the size of which should be no less than the size of the damaged disk. In the course of recovery, all contents of this disk will be deleted and replaced by decrypted data from the Bitlocker volume.
In our example, disk E: (size 2 Gb) is a USB drive the contents of which are encrypted by BitLocker, and which cannot be opened for some reason. To recover data, we have installed an additional external disk F: (size 16 Gb).
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-9.png
Method 1. Data recovery with the use of a BitLocker password
In the first place, try recovering data with this method (it will work with Windows 8 / 2012 and newer versions):
  • Launch command prompt as administrator.
  • Execute the command:
    repair-bde E: F: -pw -Force
    where E: - disk with Bitlocker data, F: - disk where decrypted data should be extracted.
  • In the course of executing the command you will have to specify BitLocker password (the same which a user is to enter into UI when trying to access an encrypted volume).
  • http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.png
Method 2. Decryption of a Bitlocker volume with a recovery key
For decryption of data located in a damaged volume which is encrypted with Bitlocker we will need a recovery key or a system startup key (if the system partition is encrypted).
Advice. BitLockerRecoveryKey is a unique sequence of 48 symbols. The recovery key is generated when a Bitlocker volume is created; it can be printed, saved as a text file to a local (this choice is not recommended) or external disk, or in a user account at Microsoft website.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.png
Now let us launch data recovery with the help of this key:
repair-bde E: F: -rp 011407-712393-682121-100210-377003-405174-520014-328130 -Force
If Bitlocker is used for encryption of the system partition containing Windows, and for loading the system a special startup key on a USB drive is used, the encrypted volume can be decrypted as follows:
repair-bde E: F: -rk I:\3F558473-943D-4330-8449-62C36BA53345.BEK -Force
where file 3F558473-943D-4330-8449-62C36BA53345.BEK is a key to launch BitLocker disk encryption on a USB drive G: (by default, this file is hidden).
After the procedure of data recovery and decryption, before opening the disk where the contents of the Bitlocker volume were extracted, it is necessary to run its check. In order to do it, execute the following command and wait until it is complete:
Chkdsk F: /f
Important note. If you failed to recover data from an encrypted disk with the described methods, it is worth trying to create a sector-by-sector copy of the damaged disk with the help of a Linux utility DDRescue (or any other similar utility). After that, try recovering data from the received copy by the following scenario.
Data Recovery Software
We also should notice that exist more common and simpler way to recover files from Bitlocker encrypted storage. These are data recovery software. Of course, not all programs ?an cope in such situation but some of them have required function.
The only thing is that you must have a password to unlock the device which was specified when encrypt.
Then it's simple. Connecting device with the information that you want to recover to your computer and getting message.
Further, enter password in a special window after double-clicking on the device you need to recover in "This PC".
After that, the storage becomes fully accessible for data recovery for any of the Hetman Software programs.
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
Tip
In this article we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where
  • Recovery key;
Chkdsk F: /f
After that, the storage becomes fully accessible for data recovery for Hetman Partition Recovery.
https://hetmanrecovery.com/recovery_news/how-to-recover-data-from-disk-encrypted-bitloker.htm
on May 05, 2016 | Hetman Partition Recovery - Recover...
Advent 7211 recovery disk needed
Well,bro! your question is too simple, why do you need yo recover disk? Did you delete or formate some important files in the disk? And the most important is that have you save new data to the disk, which will have an effect on data recovery. OK, if you need to recover disk ,you can ask help for some data recovery program, such as Recuva, which is without paying,but it just can recover about 60% data, maybe you can choose other one, know more here: http://www.card-data-recovery.com/
Mar 23, 2013 | Advent Netbook
Recover deleted files in sony dcrsr68 camcorder
Unless the disk has been physically damaged there are ways to work backwards and do camcorder recovery
I recommend you use Tenorshare Data Recovery, it not only can recover videos from camcorder, but also can recover photos from camcorder .
Tutorial:
http://www.any-data-recovery.com/topics/photo/camcorder-recovery.html
Apr 17, 2012 | Sony DCRSR68 Camcorder
How do i reformat my asus k42n series but it didn't come with an installer
To speed up your computer/hard disk then you need to maintain your hard disk.
Hard disk maintenance should be carried once a month.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Nov 25, 2011 | ASUS Computers & Internet
My 310gb transend hard disk all foders became shortcut lnk files size shows 2kb,please guide me to recover data?
Hi there,your external hard disk may be infected by virus.Firstly,remove the virus with anti-virus software in your computer.Then you can recover your files from hard disk with third party data recovery software.I have succeed to recover files from hard disk with Tenorshare data recovery.It can recover data after deeply scanning your hard disk to look for lost data.
By the way,you can download a trial version and scan your hard disk for free to preview whether your files can be recovered. http://www.any-data-recovery.com/index.htm
Jun 24, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
No recovery disk need to recover computer
ok need to know what laptop make model ect...
Oct 31, 2009 | Toshiba Satellite M45-S265 Notebook
Wd passport reports error. When connected to external power supply the disk shows up in Device Manager but not in Disk Management. Can you help? I need to recover the content of the disk.
If you need to recover a drive which doesn't appear as a disk in Disk MAnager, chances are you'll need a pro with a proper facility.
Comment back with you Country, State and City and I will point you in the right direction.
Chris
Jul 16, 2009 | Computers & Internet
Wont load windows only says f11 to run operating systems or control alt. delete to restart do i need a recovery disk
hi frined
ur hard disk has been need to recover or its has been dmaged or its have a bed cristels in ur hard disk that y this earror come
which compny u have hard disk
then downlod the dm(disk managemet) software to recover ur hard drive
Mar 31, 2008 | Computers & Internet
Acer Emachines E525 E625 E627 E630 E725 Palmrest Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
