Question about HP Pavilion dv6000z Notebook
What is hibernate
Hibernate
    Novelist:
  • 180 Answers
Hibernation is when your computer powers down but saves all open programs into memory so that when you restart your system, they all open up again without you having to do it. You must have at least as much free space on your hard drive to store that which is in your RAM. To enable it, right click on your desktop, choose Properties, choose your Screen Saver tab and then Power. Click the Hibernate tab (it won't be available if you computer doesn't have the option) and then check Enable Hibernation. Click OK.
Thanks for using Fixya.com. Please rate this accordingly. If you have any further questions, ask away! I'm here all day.
Posted on Jan 10, 2009
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
or
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
or
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
Tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
How i can enable hibernate option
xp
To automatically put your computer into hibernation
You must be logged on to your computer with an owner account in order to complete this procedure.
1. Open Power Options in Control Panel. (Click Start, click Control Panel, and then double-click Power Options.)
2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
vista
Go to the command prompt icon in the Start menu under Accessories and right click the icon: click "Run as administrator".
Paste: "powercfg.exe /hibernate on" and hit Enter and also paste "powercfg -h on" and hit enter just to be safe.
Open Control Panel and type in "Hibernate" in the Search.
Click "Turn hibernation on or off"
Click "Change advance power settings"
Scroll to and expand the "Sleep" option.
Select "Off" to the "Allow hybrid sleep" option.
Scroll to and expand the "Power buttons and lid" option.
Select "Hibernate" for the "Sleep button action" option. 10. Select "Hibernate" for the "Start menu power button" option.
windows 7
Click the Start button, and then click the arrow next to the Shut down button.
Sleep and Hibernate located on the menu
If sleep or hibernate aren't available, it might be for one or more of the following reasons:
Dec 05, 2010 | Dell OptiPlex GX620 PC Desktop
Hibernation file corrupt or missing on bootup how do I delete this message
Try disabling the hibernation feature, rebooting your laptop, then re-enabling the hibernation feature. This will delete the hibernation file.
Next time you hibernate your system, the hibernation file will be recreated.
Sep 05, 2010 | NEC Versa LXi Notebook
My hibernation option is gone.....
Hibernation may be disabled by default in XP.
Go into Start > Settings > Control Panel > Power Options. Click on the Hibernate tab, then check the Enable Hibernation check box to enable it.
Otherwise:
You can start hibernation of your PC manually, if hibernation is enabled, by:
1. Selecting 'Turn Off The Computer'' from the Start menu.
2. Normally the left choice on the resulting pop-up window is ''Stand-By''. But, if you hold down the Shift key it becomes ''Hibernate''. So holding down the Shift-Key and clicking on the resulting ''Hibernate'' button (the left-most button) will cause your computer to start hibernation mode.
Note that many computers also have a button for starting hibernation mode also. Often pressing the Power button while the computer is on will cause it to go into Hibernation. (Sometimes desktop computers have this option disabled, but it can be enabled through some Setup menu item (unless a special key has been assigned to do it on the keyboard.)
Hope helpful.
Mar 18, 2010 | Compaq Computers & Internet
How I can enable Hibernate and Stand By button? I have windows XP SP3
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Sep 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
The option for hibernating just disappeared. Somebody told me that it had to do with the video card. I have an hp Pavilion dv2000,Vista OS. I can't find the drivers for the video card, so I can't reinstall...
the disk clean up in vista will have included a large file for hibernate file cleaner if selected to be removed hibernate is disabled
re-enable hibernate if this has happened:
How to enable hibernate option in windows vista for those of you who mistakenly deleted your hibernation file using disk clean up, to re-enable your deleted hibernation file, click the start menu and then go to all programs - accessories - Command Prompt. Right-click command prompt and select "run as administrator".
When Command prompt has opened, enter the following
powercfg /hibernate on (note the space between powercfg and /) so it's not powercfg/hibernate on or powercfg/hibernateon it is powercfg /hibernate on
This should re-enable hibernation
May 12, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion dv6000z Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
