Question about Dell Inspiron 8600 Notebook
Broadcom 440x 10/100 Integrated Controller driver will not load
Inspiron 8600 running Windows XP
Machine had a liquid spill on keyboard. Keyboard is damaged, one memory chip failed, main battery is discharged with flashing yellow "fatal error" lights and RTC battery is also dead.
Machine starts and runs fine on AC adapter, with the exception that the RJ-45 port is not functional.
Device Manager reports that the device cannot start.
Administrative Utilities reports Event ID 5008: invalid network address.
Dell Diagnostics reports error code 3B00.0788 -"EEPROM Checksum failure detected. Expected 009Fh received 006Fh.'
Drivers have been unistalled and re-installed from the Resource CD, Dell Support and Broadcom, with no effect.
Device is a Broadcom 440x 10/100 Integrated Controller.
I downloaded a DOS diagnostic program that will reprogram the EEPROM, but I do not have the "eeprom.bin" file I need.
Any advice would be appreciated.
  • 3,940 Answers
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Posted on Jan 25, 2009
Dell DOES NOT provide all the downloads for their drivers..... Can anyone tell me where to get a driver download for a Dell Inspiron B130 "Network Controller"?
http://download.cnet.com/network-broadcom-440x-10/3000-2112_4-176199.html http://download.cnet.com/network-broadcom-broadcom-bcm2045/3000-2108_4-177233.html http://download.cnet.com/network-sis-900-pci/3000-2112_4-109103.html if these packages are not the right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for eg: motherboard name you might have to try a few times to get it right also you might try slimdrivers Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Feb 24, 2013 | Dell Inspiron B130 Notebook
How to intalled broadcom net extreme ethernet contoller
You can download the driver for "Broadcom Ethernet Controller" from the following link: http://download.cnet.com/Network-Broadcom-440x-10-100-Integrated-Controller-Driver-Version-A02/3000-2112_4-176199.html After opening this link, click on 'Download now'. When a pop window appears, click on 'Run'. The driver will install automatically.
Jul 04, 2011 | Microsoft Windows XP Professional PC...
I have fit a new hard drive and loaded microsoft windows on a fujisu laptop but I have a problem getting the ethernet drivers and sound drivers can you help
The Fujitsu site should help, they have a page with the available drivers listed. I've included a link to this page below. Hope it helps!
AMILPRO V2000
Oct 05, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Cannot get Internet connection with Broadcom 440x controller.
are you sure the connection in "my network places" is for that adaptor? try going to system properties - hardware - deivice manager and check the network card is properly installed there. you may need to update the drivers which u will obvioucly have to download from another computer.
Jul 02, 2009 | Broadcom Computers & Internet
Browsers on Dell Inspiron E1505 won't bring up pages
Open a command prompt and type the following command:
netsh winsock reset
This works wonders on mysterious networking problems like the one you describe here.
Hope this helps.
Feb 28, 2009 | Dell Inspiron E1505 Notebook
Inspriton 8600, XP SP1a not recognizing Integrated Net Controller
try to run in safe mode.
press F8 key when u power up then enter s safe mode.
then remove sp3 f u enter success fully in safe mode.
then type in run "chkdsk /r"
then press enter "y"
then restart the computer.
Jan 12, 2009 | Dell Inspiron 8600 Notebook
Broadcom 440x driver won't load
if you are getting a broadcom failure of the motherboard after a chapagne spill on the system, there is a good likelyhood that the controller chip for the motherboard is damaged.
If the system is POSTING and booting normally aside from the Network adapter, I'd try using a PCMCIA or USB NIC to replace the onboard NIC (Disable on-board in BIOS) If the system is manefesting other errors, then a replacement of the motherboard would be warranted
Jan 10, 2009 | Dell Inspiron 8600 Notebook
Broadcom 440x integrated controller drive will not load
...Others may DISAGREE with this repair, but I have done this on countless laptops with a SPILL...
This is a ..(LAST RESORT) fix...
remove the KEYBOARD, rinse THOROUGHLY under gaucet, while briskly wiping key surface with 2" paint brush... Shake dry. wrap keyboard in a BIG BEACH TOWEL, place it in SPIN DRYER, set for SPIN CYCLE (only), and.... let 'er go... Then AIR DRY it overnite, reinstall.
... If MoBo wasn't also damaged by spill, this may be your answer !! Doug R.
Jan 10, 2009 | Computers & Internet
Device Drivers
Kindly download the requested drivers from the link below.
http://tinyurl.com/656myq
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - Proton
Oct 20, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 8600 Notebook Logo
1,255 people viewed this question
Alun Cox
