Top part of agitator came off frigidaire top load washer
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 432 Answers
SOURCE: I have the dog agits to replace Whirlpool top load
On mine I pulled on the fabric softener plastic top.And under it was a cap. I pulled the cap off and looked inside to see a bolt (I think it was a 1/2" size. I needed a 1/2" socked and a 6" long extension and took the bolt completly loose. Righty tighty ,Lefty loosey. Then I just pulled up on big center plastic part and the dogs are under it. I hope this helps you.
Posted on Sep 04, 2009
Frigidaire Top Load Washer Won't Agitate FWS645GFS1
i guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
Sep 15, 2008 | Frigidaire CWS3600AS Top Load Washer
How do you clear lint from water level cup on a frigidaire gallery washing maching
Hellow mariadjmaria - So I may further assist you more accurately, could you clarify what the issue is? Are you speaking about a top load washer and are you referring to the top of the agitator?
Sep 30, 2012 | Frigidaire FWS833A Top Load Washer
Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
Jun 21, 2012 | Washing Machines
How do you remove the gyrator from a frigidaire gallery top load washer
Pull the top piece off. Remove the bolt underneath the top cover.
Pull up on the agitator to get it off.
Sep 07, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
An old model Frigidaire top-load washer - the old "turn the dial, and pull out to start" type. Drum won't agitate - what, if anything, can I do?
Remove the front panel and inspect the drive belt. It is probably worn out and or stretched.
The Frigidaire style you have does not take overloading very well.
Also check the lid switch for continuity. It must be good for agitation to occur.
Nov 01, 2009 | Frigidaire FWS1339A Top Load Washer
I replaced my splash sheild
this is joyce
I would suggest to stop doing full loads or to keep top closed on washer while doing clothes. you have a very strong agitator.
thanks
joyce
Feb 06, 2009 | Frigidaire GLWS1233A Top Load Washer
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Washing Machines Logo
989 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
