Question about NetGear WGR614 Wireless Router
I have a 2wire dsl gateway and want to hookup a netgear wired router. how to
  • jmurf001 Apr 23, 2009
    I have a 2 wire dsl unit as well. I have a netgear wgr614 v6 from when we had wireless in the house. I have a dell desk top at home. is there a way for me to hook the netgear and 2wire units up so I can use my work lap top wirelessly around the house?
  • JDTec
    JDTec May 11, 2010
    which model 2Wire is it?
    Scholar:
  • 141 Answers
Call NETGEAR Technical SUPPORT. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Wireless hookup (Roku player) to DSL 2WIRE 1701 HG Gateway
make sure to configure the wireless settings of your roku player matching the wireless settings of your router. You need to do manually, go to the network settings of your roku, go to wlan settings and edit the SSID and wireless security key
Jun 28, 2009 | 2wire (1000-400108-001) Router
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire router from AT&T
You don't have to have that 2 wire router if your using DSL is it the wireless gateway one with the 802 pcmcia wireless cards?
But you can find them for cheap on ebay and depending what state your in a local PC shop could locate one. The ones for Yahoo SBC/DSL will also work as replacement for yours. But you can program other routers to work with your PPPOE user name and pass on DSL if thats what your using.
May 01, 2008 | 2wire (1000-400108-001) Router
WII internet hookup
yes, it is!
http://support.2wire.com/cgi-bin/twowire.cfg/php/enduser/std_adp.php?p_faqid=1044&p_created=1166058411&p_sid=Mm2vhi1j&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSZwX3Byb2RzPTAmcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXdpaQ**&p_li=&p_topview=1
Apr 14, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Gateway Reboots Constantly
many times, updating the firmware of the router fixes that kind of problems or resetting it to the factory settings. you can download firmwares from 2wire site and the in the router settings windows update the firmware.
Feb 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Netgear router and Vontage phone box
Have you reviewed the following page and links from it yet. They may answer your questions.
https://www.vonage.com/help.php?article=88&category=3&nav=3
Dec 22, 2007 | Computers & Internet
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
www.netgear.com
Oct 17, 2007 | 2wire HomePortal 1100 Router...
NetGear WGR614 Wireless Router Logo
66 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
