Question about GE Spacemaker JVM1750 Microwave Oven
The touchpad on my GE Spacemaker Microwave is starting to blister. It was only installed a month ago and there are 3 or four places where it is blistering, or bubbling, about the size of a dime. Mostly where we use it most ie. Number 1, "add 30 seconds". Other than that it is working fine. What is causing this?? Jim
MicrowaveSvc
  • 9085 Answers
SOURCE: GE spacemaker model #jvm1350aw-002
Usually that's due to accumulated grease and / or food particles.
They must be cleaned. If they are damaged, they must be replaced.
If this continues, it can damage the paint or the wall, which would have to be sanded and repainted with high-temperature appliance paint from places like Wal-Mart or Lowes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Model JVM1870SK04 Spacemaker XL1870
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 12, 2008
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
SOURCE: Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Posted on Mar 13, 2010
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
Oct 06, 2014 | GE Profile Spacemaker Over-the-Range...
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We received a Ge spacemaker microwave oven as a
When a microwave makes a notable HUM there are 3 things thant can cause that dreaded hum.
1. Most common failure is the diode
2. Shorted capacitor
3. The Magnetron
If you list a model number I can probably find your parts for you and pass along a couple of trouble shooting tips if your good with a meter.
Kelly
Mar 04, 2010 | Microwave Ovens
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Disconnect the wire connection on touchpad
Do you mean the keypad strip?
Jan 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacesave microwave oven isn't heating. It is about 6 years old but I only installed it and started using it 4 days ago.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhgj
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl does not heat- fuse has continuity (OHM test) help.
I am assuming that your microwave turns on and everything and that when you press the start button the table turns and all. This tells me at least that all the switches on the door are working properly and since your fuse is not blown you have power to your control panel. That being the case the magnetron (the part that does the cooking) is bad and needs to be replaced. If you are a do it yourselfer and can find the magnetron through a local supply house or the internet, replacing it is pretty straightforward. Unplug the microwave and take the cover off just a handful of screws. On the control panel side and behind and on top you will see the magnetron with cooling fins on it. The magnetron is usually held in place with three to four screws and has about 3 to four wires coming from it and going to a couple of places. These have terminals on them that unplug and there is no soldering or desoldering to do. Unplug the wires and be sure to make a small diagram as to which one goes where. Get a new magnetron and replace it. Put the cover on and you are back in business. God bless.
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dead - what to do now?
Still under warranty so someone is coming to fix it free of charge...
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1750 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
