Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Switch Problem The red switch to put on wont stay on the motor runs but as soon as you release your finger from it the motor cuts out. what do I need to do to make it work as it should?
  • 66 Answers
It sound like the switch is loose if you are able take the handle apart and plug the leads back into the switch. be sure to unplugit ffirst
Posted on Jan 24, 2009
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
No motor when switched on two red lights flash,cleaned hoover, put back together motor started,then cut out after a few seconds
I would double check your wiring, Make sure all wiring is tight. No cracks, no pinched wires. If needed, bypass the switch and see if it will stay running. If so, switch would be bad. If it's the same, then you have a wiring problem or a worn motor at the worst.
Jan 06, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Uh70015 dirt sensor stays on green. Goes on red for about 5 seconds then green. Can clearly see the floor is dirty and it is picking up stuff.
ahh the good ol electronics on vacuums selling the product again...
not to worry, your feature is working properly, your vacuum is working fine too.
Imagine if you will making a circle with your pointer finger and your thumb. Now put a string or thread across in a straight line there. The string would be the size of the beam of light that the sensor uses. Your finger and thumb are about the size of the tube that the dirt and dust is passing by. Unless the dirt passes and cuts through the beam of light, then it will register. otherwise if it passes around the beam of light, the sensor thinks your carpet is clean.
The opposite sometimes will happen too where it will stay constant red. That means that the sensor is completely covered in dirt and will not register anymore.
Hope this helps.
Nov 11, 2010 | Hoover UH70015 Bagless Upright Cyclonic...
Put in new bag but as soon as we turn vacuum on motor stops red light comes(bag full)
make sure the bag is installed properly and the bag door is making contact with the small switch by the bag.
Jan 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
The on button won't stay pressed
Faulty switch, undu the screw with a torx driver where the handle sits and unclip the switch cover out at both sides, be careful not to break it,
where the switch is situated they may be a spring, also test the button, if no good replace
Sep 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
i have one of these too and it used to keep cutting out, replaced the filters and now it wont even turn on.  changed fuses everything, and now im stuck with a dirty house....
Apr 16, 2008 | Vacuums
Overheating Dyson DC07
Many devices including this one have what's known as a thermal cut out.
It is there for obvious safety reasons and prevents the temperature in the locality of the cut out from exceeding a pre-defined value.
Some of them require you to press a reset button in order to switch the power back on and other types simply reconnect the electricity supply when the temperature returns to normal (safe) operating limits.
The Dyson DC07 has a thermal cut out located close to the motor and it is of the "self resetting" type.
If your vacuum cleaner switches off after a few minutes the most probable cause (there can be others) is the thermal cut out has operated.
The first and most important thing to do is to establish why it has operated.... If the airflow around the motor has become restricted then it will not be being sufficiently cooled and so it will have cut out correctly. However, thermal cut outs are often quite crude internally and it is not uncommon for them to start cutting out at too low a temperature. So...
Here's what to do...
(some tools may be required to complete the following so read the entire procedure before starting. Please note this is not an absolute guide if you need really foolproof step by step instructions... buy a manual! But this should help)
  • remove and thoroughly empty the dust bin (do not put it back yet)
  • remove and clean the drum filter to the right of the motor (right when looking at the front of the machine). (N.B. Never put this back if it is still damp)
  • remove the accessories from the upright section
  • withdraw the handle and separate it from the flexible hose (all of these and the following parts have a colored (commonly yellow) release tags/buttons/levers *** Never force anything!! ***
  • remove the flexible hose
  • remove the pipe union to the left of the motor
  • carefully lie the machine on its front (wheels uppermost) and remove the u-bend
Check all these parts for blockages/clogging before continuing...
There are now only two areas left that I know of which may cause further blockages. One is the "whole of life filter" located under the dust bin and the other one is inside each of those seven little cones (cyclonic chambers) at the top of the dust bin (root 8 cyclone is usually written on one of them). The following will require some tools and some common sense...
  • carefully prise the plastic disc up (the one under where the dust bin rests) use a flat bladed screwdriver or similar releasing it from the lug you can see at the front. Inspect the filter and replace if necessary (when replacing it you may find the original has been glued to the plastic lid - if so gently scrape it off )
  • If none of the above has revealed an obvious problem lets turn our attention to these pesky little cones... if you have ever vacuumed up any damp material these can become blocked. You will need a size 15 star drive (sometimes known as torx TX-15) screwdriver. I recommend you buy one with a shaft length of at least 70mm (you will need one this long if you are to access the thermal cut out later)
  • Place the bin assembly on a suitable dust sheet.. this can get messy!
  • remove the clear plastic outer bin
  • undo the three star drive screws at the top and partly withdraw the top ***careful*** you can not fully withdraw this piece. All we are doing here is creating a bit of limited access and "peer room" (before withdrawing the lid you may wish to peer underneath and for future reference note how the release rod is engaged).
  • now here you have to use a big dollop of care and common sense. By peering into these cones (shine a powerful torch through the sidewall of the cone) see if you can tell if any of them are blocked.
  • using a small piece of wire or similar gently poke any blockages away. Be careful not to damage the loose but still attached lid.
  • reassembly is a bit tricky because you have to re-engage the release rod at the bottom whilst at the same time pushing the lid back into position. Take care not to damage or trap the large rubber sealing ring as you press the lid home Finally replace the three screws being careful not to over tighten.
If none of this revealed anything very positive... Its time to open up and inspect the motor casing/thermal cut out.
**** WARNING**** The next section requires someone who is technically minded, has fiddly fingers patience and a basic understanding of typical plastic goods assembly techniques. As I am not including photo's the descriptions given can only be considered as pointers to how to do it (I'm not writing a Haynes manual here! So if you are a cak handed clot with little or no patience and a tendency to resort to ever bigger hammers - take the vacuum cleaner to an independent repair shop - explain the symptoms, tell them what you have done so far and leave it to them!!
  • In order to release the roller brush and belt mechanism turn the vacuum cleaner face down undo the three 1/4 turn screws and carefully withdraw the grey plastic cover (ease the belt guard section gently away)
  • coax the belt from the motor end then withdraw the belt and roller from its housing
  • Now we need to release the mains cable from the switch area to the motor housing - Undo the screw below the yellow switch
  • Working from the back prise the plastic housing forwards (this is tricky) leaving the switch in the on position can help but the main lugs stopping the housing from coming forwards are at the top just behind the big yellow switch button. the best way is to insert a fairly small flat bladed screwdriver in past the upper lugs at the back and put a slight outwards force on the housing tou are trying to remove... patience! Repeat for the other side
  • Now undo the electrical connections and release the flex from its channel so it is free to be withdrawn when you release the motor housing
  • turn the vacuum on to its front and remove the four torx drive motor housing securing screws (two of these are down a fairly deep recess)
  • carefully withdraw the complete motor assembly from the shell
  • The remaining part of the grey plastic casing can now be removed (a bit fiddly)
  • You should now have the complete motor assembly housed in a black plastic case with the grey intake at one end. Inspect this carefully and you will see that the grey intake is held in place with four lugs. gently prise the black plastic over these lugs and the grey intake will come away
  • Now you need to do two things in stages - pressing on the shiny metal motor shaft will push the motor out of the black casing but make sure that at the same time you feed the mains flex complete with rubber boot through the hole.
  • Voila the motor is now exposed
  • Inspect the motor for any signs of overheating or damage - check the brushes are OK (if you don't know what these are and you've got this far, now may be the time to ask a friend with a bit more knowhow to help!)
  • Unplug the electrical connections and undo the small Phillips screw holding the plastic assembly to the motor casing (this contains a capacitor and firmly pressed against the metal motor casing is the thermal cut out
  • If all else seems OK replace the thermal cut out with a new one and reassemble
  • No I'm not going to explain how to do that! For the most part just carefully reverse these instructions! - come on you've made it this far!!
NB. NEVER remove or bypass the cut out. this really could be very dangerous!
I hope this is of some help... Regards to all.
Sep 02, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
