Question about GE DVL223GB Gas Dryer
Dryer will not stop running, but dries clothes fine.
GE Dryer: DBXR463EB1WW approximately 5yrs old:
I recently replaced both heat coils on the dryer due to it not completely drying the clothes after long dry times. Now the dryer dries the clothes fine, but will not shut off in cotton dial setting. It will shut off in the timed setting on the timer so I was told the timer is probably not the problem. My next option is to replace a thermostat, but which one, I am not sure. I was going to try the drum outlet first, but I am looking for a definitive answer to save money by not replacing the wrong thermostat. I measured across based control inlet, thermo hi-limit right, and safety left thermostats for continuity and they tested fine, but I was told having continuity will not necessarily tell me the thermostat is bad due to it opening and closing @ appropriate heat temps. I did not measure across the drum outlet thermostat yet as it was located down below. BTW: the ductwork is clean of lint down the pike to the outside- I checked that first! Help????
Thanks.
Monte
    Genius:
  • 1,239 Answers
Hi It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Posted on Jan 10, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 10, 2009
    If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this
    or There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
    Sergeant:
  • 431 Answers
The problem would be with the timer circuit in the drier. Check the board with any problems. The timer would work when used individually, but when used under cotton dial setting, the specific information from the thermostat would ave not reached the circuit thereby deactivating the timer. Try repalcing the board if possible instead of thermostat.
  • GE Master
  • 19,396 Answers
It is either a faulty thermostat or a faulty control, I will tell you more,
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer stopped heating
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 03, 2009 | GE DSXH43EF Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer will not dry clothes
make sure the vent is clear that runs to the outside of the house.
Jun 26, 2009 | GE DCSR483EA Electric Dryer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 06, 2009 | GE Dryers
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
GE DVL223GB Gas Dryer Logo
87 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
