Question about Xantrex Technology DR3624 Inverter/Charger
Xantrex control board 200-0160-01-01 R1 94v 1504
I need this hardware interface, where can I buy it, or alternative?
I have a Heart Interface Freedom 20 inverter in a 95 American Dream, the inverter part number is 81-0209-12. It was subjected to a voltage surge by a runaway generator that lasted about 30 seconds. The...
Check with BR Wholsale, Marshall Mi or Marysville Marine, Marysville, MI they do some service work and may have additonal insight on how to resolve or find parts.
Jun 17, 2011 | Xantrex Technology Heart Freedom 20 12...
During the drying cycle, the indicator lights for "Cycle Signal Volume - Loud & Soft" alternate with a flash and beeping sound, what could be the problem?
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(())
Sep 20, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore 110.27082603 top load washing machine. When it runs the cycle signal volume keeps beeping and alternating between load and soft. Otherwise it seems to run fine
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Aug 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I need a control board.
You could buy the control board from :-
http://cgi.ebay.com/Xantrex-Inverter-Repair-Board-DR3624-Control-Board-/260652658387?pt=LH_DefaultDomain_0
I hope i have been helpful.
Thank you!!
Aug 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
I need a replacement comm board for a Xantrex Freedom Marine 25-12 Inverter/Charger. The battery temp sensor got shorted out and probably caused damage to the installed comm board.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Jul 03, 2010 | Xantrex Technology Heart Freedom 30...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
I have a Freedom invertor/charger 458 in my motorhome and i can't control the invertor with my remote board. I can push any button and nothing happens/no lights come on. it still charges and inverts. is...
Buy a long phone cord or however long youneed. Run it temporarily to the remote board and the invertor. Make sure powrr is off during this stage.If this doesn't work the solution is probaly going tobe much tougher. See manual.
Here is the owner's manual.http://www.donrowe.com/user_guides/xantrex/fdm_basic_remote.pdf
Feb 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
Xantrex Technology DR3624 Inverter/Charger Logo
48 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
