Question about Zebra LP 2844 Thermal Printer
TLP 2544-Z customer is looking for a TLP 2544-Z Does LP 2844 replaces the TLP 2544-Z
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
  • 124 Answers
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Posted on Jun 15, 2009
  • 185 Answers
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Posted on Dec 20, 2009
How to print configuration page for zebra lp 2844-z
With the printer off, press and hold the FEED key while you turn the printer on. When the LED flashes once, let go and a Config label will print.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My zebra tlp 2844 prints one line and stops then the red light comes on and it does nothing
Check the driver settings are set correctly, if you are NOT using a ribbon set for Direct Thermal. If you ARE using a ribbon make sure the driver is set as Thermal Transfer. This should fix the red light problem.
Mar 26, 2010 | Zebra LP 2844 Thermal Printer
Prints out 13 stickers with strange characters
Is this a 2844Z? the 2844 is an EPL printer and the 2844Z is a ZPL printer. Since your have described the printer as 2844 but mentioned that you are performing 3-flash proceedures, it sounds like you have installed the wrong driver. uninstall the driver and install the LP2844z driver so that you can send the correct print language to the printer. If this is not the case, then you need to clarify:
What is your model?
Details about the driver installed?
Firmware version of your printer?
Connectivity? (Serial, USB or Parlallel)?
What are the characters that are coming out on the page? ASCII -Extended?
Jan 19, 2010 | Zebra LP 2844 Thermal Printer
I have TLP 2844 its printing very poor quality
Download zebra setup utility and use it to configure print quality.
Sep 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Labels come out blank using XP & Zebra TLP 2844
check the value of the darkness (Heat) in your printer driver setting. Normal range is 0 to 15. 0 being lowest heat 15 hottest. Value of 0 will cause labels to print out blank.
Jul 28, 2009 | Zebra LP 2844 Thermal Printer
TLP-2844 ink not thermal-transferring (labels are blank)
Ribbon is probably not installed correctly. Call Andrew @ 908-725-1699 for free tech support
May 05, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
LP 2824
Here's the right way to fix the problem.
Autosense Procedure, Configuration Label and Dump Mode:
Models: Orion (2442, 2443 and 2543), Transport (P-2242), Xport (P-2222), LP/TLP Strata (2684), LP/TLP-2722, 2742, 3742, LP/TLP-2824 ,LP/TLP 2844 and TLP-3842
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the "Out of Dump" message on it.
Printer is now ready for use.
Oct 10, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
77 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
