HP DV7-3085DX Shut down at 120 degrees C
I have an HP DV7-3085DX laptop that shuts down when the motherboard reaches around 120 degrees celcius. The fan has been cleaned out and new paste added, new hard drive with a new build of WIndows 7 Ultimate 64-bit, no battery. System works fine when sitting idle. once you start something simple like surfing, it shuts down. I run a fan under the unit and it runs fine as well. What the heck could it be? HELP!!!!!!
  • Norm Stormin Nov 28, 2012
    Also I have never seen a laptop without a vent opening directly below the fan. Is this normal?
  • 2,878 Answers
No solution, but that is really hot. Hot enough to start frying other components. Eventually it will.
Posted on Nov 29, 2012
3 Suggested Answers
RonPark
  • 855 Answers
SOURCE: ASUS M51SN Matshita BD UJ-120 burner does not work - Windows 7
You need to install windows 7 (32 bit) not 64. To change to 64 you have to make internal changes and updates to your notebook. Your notebook is set up for 32 bit systems.
Posted on May 19, 2010
  • 109 Answers
this will be an isue with the drivers for the drive you will have to get the windows 7 drivers
Posted on May 20, 2010
Testimonial: "Not really helpful as I can't locate drivers for the BD UJ-120 burner"
The screen displays "LOCK OUT APS FAIL (close)"
sounds like a service call wold be in order . things like boilers and furnaces are best left to the pro's
Feb 16, 2015 | Water Heaters
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
My hp pavillon dv5 fan works but little air comes out of it
first of all open ur laptop back cover if u can do this.... u willl see fan will be attach along with motherboad so remove fan carefully from mothrborad and clean fan heatsink from dust..
Jan 08, 2014 | HP Computers & Internet
Is my laptop too hot?
Hi and welcome to fixya
Mitchell Baker when the cores are getting at 95c you should stop playing the game . but ! this is not dangerous because your laptop will automatically (shutdown) when the cores will reach 105c
hope that will be helpful
Dec 27, 2012 | Computers & Internet
My pc heats up to 90 degrees celcius and switches off on its own, what can I do? I acquired a virus which shut my computer and I did not manage to restore it to its original working condition. After...
Check your processor heat sink and fan. It may be clogged with dust. Clean the heat sink and fan with an unused paint brush and use slightly wet cotton buds in cleaning the fan blades to remove the dirt.
Sep 21, 2011 | HP Pavilion dv6000 Motherboard
Hp mini 210 shuts down abruptly? highest processor temp reached 124 degrees. been through the ringer with hp...they had me do a complete restore and check all vitals cdm, config, etc...what can be causing...
If the unit is new and you still have that option to take it back, I would because this could also be a system board or power supply problem. In our company we use Lenovo and that product works well.
Nov 18, 2010 | Computers & Internet
It all of a sudden shuts down
for your suddenly shut down there might be a virus in your motherboard ''Brontoc'' or ''foooool''
they might harm your motherboard install the anti-virus you trust ''best use avg free 8.5.87,download from www.filehippo.com''
second for your ram you can increase them as much as you want so you can reach your limit to 4GB RAM
i wish this helped you
Apr 11, 2009 | HP Pavilion dv4000 Notebook
Computer runs too hot then shuts down
remove your fan and install new one ,your hit sneak is not working properly ................ok
Apr 03, 2009 | Acer Aspire One PC Notebook
Hp laptop shuts itself down
Laptops are designed (by software) to shut themselves off as a protection measure. The most common problem is high temperatures. Do you hear your fan racing while you are using it? Do you sit your laptop on soft surfaces (like the bed or carpet floor) while using it? Do you smoke around your laptop while using it? These are common things that cause high temperatures on your laptop and will cause it to shut down. May not be your case but just a though. I would take it somewhere or open it up yourself(if you are pass your warranty time ONLY) and clean out the dusk with some air.
Hope this helps!
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion dv5-1000us Notebook PC
Oven Shut Down
check for a blown fuse or tripped circuit breaker...It is most likely the fuse..
Oct 26, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
