Question about 5.5 HP GX160 Engine
Honda gx 160 runs for 30 minutes then shuts off and wont re-start
  • Frank Alvarez Nov 30, 2012
    Could this engine be vapor locking after running a while? If so how do I correct it?. If it was the oil shut off it wouldn't start to begin with right? Oil level is full
  • 34 Answers
Try checking the fuel filter and or line. Sometimes dirt is drawn in to plug the line, then settles back down later.
Posted on Apr 26, 2014
I have a Honda GX 160 5.5 Power washer Model Number: CM2403. What kind of oil should i be using in the engine?
If it has a Briggs engine then use SAE 30 oil. If you run synthetic (which I highly recommend), then SAE 30 or muti-viscosity oil like 10W-30 can be used, but if using conventional oil, only SAE30.
May 25, 2011 | Garden
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
Hard starting after sitting
adjust your idle screw in carburetor clockwise one or two full turns. When Honda's are cold, they need higher idle to start properly.
Feb 06, 2010 | Honda Jenny K5HGA-30P 5.5 30 Gallon GX...
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
5.5 HP GX160 Engine Logo
293 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
