Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water runs out of the rubber gasket inside the door
Water runs out of the rubber gasket hole inside the door when the cycle is finished and the door is open. It seems to be only hot water. I have to run the cycle through a few more times to get it to stop. There are no error codes since the door is open and cycle complete.
  • hainescm Jan 10, 2009
    replace water inlet vale.is that expensive ?
    Sergeant:
    Champion:
  • 262 Answers
Replace water inlet vale it has gotten debris in it and not allowing it to close
Posted on Jan 10, 2009
  • Bill Dozier Jan 10, 2009
    if you do it your self it will cost ya about 65.00 or less if you buy the part at a appliance supply house you can go on appliancepartspro.com and find it and it will give you a idea for the cost but dont use there part numbers they are different from OEM parts or just get it from them you have to pay shipping but some times it is easier than dealing with the parts house and driving there several time if they have to order it I have bought stuff from them and have had no problems let me know
    .bill
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
What can be used to clean inside the machine
White vinegar and hot water on a hot/sanitize cycle. Also make sure to clean the rubber gasket / door seal and leave the door open to evaporate the left over moisture.
Aug 18, 2012 | Frigidaire ATF6000ES Front Load Washer
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have mold all around the rubber gasket on the fromt of my LG washer. How can I eliminate this?
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
Service manual and more HERE
Feb 10, 2011 | LG WM-1832C Front Load Washer
Water leaks from door during last cycle
Sometimes residue builds up between the gasket ( rubber on the back of the door ) and the unit itself. With the door open clean the inside of the washer where the door touches it when closed, clean the gasket too.
When dishwashers aren't run frequently the gaskets can dryout and shrink, this creates a gap in the gasket and allows it to leak. New gaskets are available from your dishwasher manufacturer.
Dec 30, 2010 | Estate 24 in. TUD6700KQ / TUD6700KT /...
I want to clean can i run thru with vinger,bleach and what else can i do?
With the machine off, open the door and spray Clorox Clean-Up inside of the front rubber door seal/gasket. You should be able to gently flex the rubber seal to get inside of its cavity. This is where mold, etc. tends to accumulate. After a minute or so, brush or wipe away any debris that has accumulated. Be careful not to wear good clothes! Once you have completed the gasket/seal cleaning, begin a hot water cycle with no detergent to thoroughly rinse the bleach from the door seal/gasket.
From then on, occassionally glance inside the gasket/seal to see whether there is a build-up of mold, etc. and repeat the aforementioned process.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water runs after unit is shut off and door is open
It could be 1 of 2 things either your water valve is going bad or the screens on the back were the hoses connect are dirty.
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Neptune 2000 stackable washer. It seems that water is always remaining in the drum after a cycle, and water is sitting in the rubber gasket at the door. I am getting mold on the gasket and odor...
All washers still have some water in them at the end of the cycle. If you wipe the door boot down with a mild bleach and water solution this will keep it from getting mold. If you don't do a bleach load on a regular basis I would run a hot wash with 1/2 cup bleach and 1/2 cup powder cascade with no clothes once a month to keep the machine cleaned out. I also always leave my door unlatched when not in use.
Apr 23, 2008 | Washing Machines
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
