Question about HP Pavilion Notebook
Memory test failed
I ran a run-in test it stated memory test failed
    Sergeant:
  • HP Expert
  • 427 Answers
Change the memory
Posted on Apr 17, 2013
2006 Suzuki Reno, bat ran down, recharged bat, now car will not pass emission control. How do I reset computer?
so easy like falling off a long
well you for got to run car long enough to complete all EPA
mandated monitors, all scan tools show this, completed monitors.
drive for 1hr. fast and slow, over 50 and then city
done.
or learn to scan
reseting the pcm is dead wrong now, if CEL is off
if you do it wrong , you fail every time.
is this hard>
1: CEL lamp off, driving. if not FAIL (USA)
2a: all monitors must be clear, ( 1 allowed not done in some states)
2b, drive for 1hr, end all this worry.
3a:? gas cap good. and no DTC errors for it and evap
see #1
in most states you have to pass a tank filler pressure test.
this can be easy to fail.
Feb 07, 2017 | 2006 Suzuki Reno
99 S10 battery check good 25% life left though 14.5 volts when running ran it about 30 min Battery reads 12.66 seams to repeatily drain till dead
replace the battery
battery cells will give a good reading until a load is applied then they fail quickly
for example a battery will read 12 volts or better in a static state but when a load is applied ( cranking , lights etc) the voltage will fall to 10 volts or less
the 14.5 volts you are treading is from an working alternator
the proper way to test a battery is with a load test machine
take the car to a battery shop and have it tested properly and while there have them replace the battery using ther standby battery that keeps all the radio codes and ecm memory operational
Sep 06, 2016 | Chevrolet S 10 Cars & Trucks
My emachines ran fine last nite-tonight I get a 2-3 second beep with 2 flashes of the power button no power to monitor to see any messages or ability to get into anything. Fan is running. I believe it is...
Memory problem
Try reseating the Ram modules on the motherboard, if 2 inserted, replace one at a time and test in each slot. Check both modules are running at the same speed (eg: PC3200 / DDR 400)
Not uncommon for memory modules to fail. If you get it back running again, download memtest and run it for an hour to see if it flags up Ram issues
Dec 31, 2010 | E-Machines eMachines Desktop PC
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
My computer wont start up and so i ran a bios primary hard disk self test and it says failed test status 7 (completed with the read element of the test failed) my computer is a hp netbook mini 1000 what...
If it is within warranty, send it back quick-smart.
sounds like the SSD (solid state drive) has died.
i got one of these errors at work on a Dell mini only yesterday!
Jul 13, 2010 | Computers & Internet
I ran diagnostics on my Dell Inspiron 1525. Results: Data Bus stress test failed. Memory compare error, DIMM-B. Suggestion: try to reseat the memory. How should I do? Please help! Thanks T.Doan
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
WMI Error
I'm pretty sure you have a failing hard drive. Try dowlnloading diskeeper 2009 trial & see what it shows for fragmentation of the drive. Run the program & defrag the drive. If that doesn't help you can look for a program called tuff test & check the drive that way. That's the sure fire way to find out. If the drive passes tuff test then back up your important stuff & reformat & re-install the os. Use google to find tuff test. Good luck!
May 03, 2009 | Computers & Internet
Dell blue screen tests got data bus system
I presume you ran the 32bit Dell diagnostics. The memory test failure indicates that the memory module has failed. If you have more than one memory installed, you can try removing one at a time and run only the memory test (from Custom test option), this way you can isolate the faulty memory. If you have a warranty for the computer, Dell would replace the memory for you (Check warranty status from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen )
As for your other problem “it just does nothing when i type r for recovery”, you would need to go to the bios, under the “Drives” tree, under “SATA operation” you would need to change option one to two and save and exit. This is applicable on for the Dim 8400. But you would not need to do this if the prvious steps resolve you issue
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell Dimension 8400 PC Desktop
Dell inspiron 1525 memory test failure
Were you able to do a virus scan
try to get on in safe mode by constantly pressing F8 during restar select safemode
See if shutsdown in safemode
Do you here the fans running when it's on
You may just need to do a restore
Let me know what happens in safe mode
Jan 19, 2009 | Dell Inspiron 1525 Laptop Jet Black
HP Pavilion Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
