Question about Intel Desktop Board D845EPI Motherboard
No display on monitor
I replaced the power supply and mother board on my PC. The fans all turn on, the green LED light on the motherboard turns on, and the light on the front of the PC turns on but nothing else happens. When I turn the switch to the power supply off, the PC makes the noise it should when turning off. All cables were applied exactly like the original installation.
Thanks
Preston
  • 2 more comments
  • tlonghorn79 Jan 10, 2009
    When it shuts off, it just makes one beep. When started, the monitor remains in the "sleep" mode and pressing the delete button does not initiate a response either. I noticed that when it is started the 3 lock keys at the top of the keyboard light up then go away immediately. Reconnecting the plugs also did not help
  • Anonymous Feb 21, 2009
    grafic
  • Jeff May 11, 2010
    From what you are reporting, ther is something that is not connected properly or completely. The single beep and then the keyboard lights coming on are generally an indicator that the motherboard is booting up. Is the video integrated into the motherboard or on a separate card? Do you have another video card?
  • Jeff May 11, 2010
    When you say that when shutting off, it makes the "noise it should when turning off", what do you mean? Are you hearing the Windows sounds or just some beeps?
    When the computer is started, do you see anything on the monitor at all? Any BIOS messages or startups from the system at all?
    As the computer is started, try pressing the Delete key and see if the BIOS comes up. If you can see that, then the power is getting to the system and you can also see what video is selected there.
    If you can't get to that (and you may have already done this), disconnect and reconnect all of the plugs and re-seat the RAM.
  • 3 Answers
Check your RAM card and Video adapter .Because problem of one of that thing computer wont on the monitor video.
Posted on Jan 11, 2009
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
Oct 09, 2009 | E-Machines eMachines Desktop PC
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Tried to turn it on, no powr. Replaced the power supply, little led on the mother board, but no power, no fans.
no beeps.
I tried 3 different power supplies.
I stripped out the memory and hard drive and put it in the dumpster where it belonged.
Steve
Jun 09, 2008 | E-Machines T2240 PC Desktop
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
PC not booting
the mother board can have a short and the green light is on, replace the motherboard. when the power box goes bad, most of the time it shorts the mother board out, this has happened to me a few times. Farren
Dec 25, 2007 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Intel Desktop Board D845EPI Motherboard Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
