Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My Frigidaire FEX831FS overflows on all water level settings. How do I check the water pump filter to clean and look for clogs etc?
I would like to know how to check/clean the water pump filter for clogs etc. I want to see if this is the problem first then check the actual pump for failure etc. What is your suggestion so I can do it myself before calling someone?
  • Official Brand Answer
  • 4,342 Answers
Hello clarksurf211 - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Nov 30, 2012
  • 262 Answers
SOURCE: Won't drain...
on the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
Posted on Jan 17, 2008
Lumpy816
  • 246 Answers
SOURCE: Frigidaire washer/dryer combo
For that model you should just be going through the front. There are 2 phillips screws at the bottom of the front panel. After you remove those, you will need to slide the front panel down. (sometimes insreting a large flat head screw driver between the top washer panel and the front washer panel will help ease it off). The pump on this one is one of the easier one's to clean. Use a shop vacume or just bail the water out by hand to remove as much as possible. Follow the large black hose running down from your tub to the white plastic looking peice. That is your pump. The are 2 5/16 screws holding it down. Remove these to make your work easier and cleaner. Also remove the connector/ wires that plug into the side of the pump. Once removed raise your pump up and slide a large, flat container underneath. Squeeze the clamp on the hose and slide it further back up the hose. Now, SLOWLY start working the hose off in a rocking motion. Just a little pressure here. Now as it strats to work off, the rest of the water will start to come out. Drain it a little at a time. Work the hose back on if you have to go empty your container. Once all of the water has been removed, pull the hose the rest of the way off. Do you see anything blocking it? No? Remove the hose coming back out of the pump as well. Still nothing? Try removing the hose that goes between the tub and the pump up by the tub this time. Nothing yet? Try plugging the pump back in and setting it to a spin/ drain cycle. (make sure you are not on the part of the cycle that adds water or there will be a mess) Once you are on the spin/ drain cycle, look into the pump. Is the paddle wheel looking piece inside moving? If it is not, and there are no forign objects in there, it may be time to replace the pump itself.
Posted on Jun 25, 2008
aborcass
  • 2651 Answers
SOURCE: I just bought a Frigidaire Affinity washer model
perhaps not in that hose but in the pump housing just below it, quite possible that someting is jamming the imopellar preventing proper draining of water
Posted on Mar 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire GLWS1339EC Washer Overflowing
Do not blow to the switch. Blow from the switch to the tub. The blockage is soap scum in the air bell on the side of the tub. You may have to run a small wire into the tub area where the air hose attaches on the side of the tub.
Posted on Dec 05, 2009
SOURCE: my washer will not drain the water and the spin-Model ATF6000FS1
I had the same problem but bought a new washer. As we were parting this washer out we found that there is a black rubber boot the attaches to the water pump. There is a filter inside of this boot and it was clogged with hair, string, and almost 2 bucks in change. No wonder it wouldnt drain. Check yours and see if thats your problem too!
Posted on Sep 21, 2010
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
Why has the circulation flow decreased
Your pump pushes "Unfiltered" water thru the Filter. Your filter then "Cleans / Filters" all of the microscopic particles of dirt out of the water. This will eventually clog your filter as the pressure will then obviously climb. Basically, doing the job it was intended to do! As this occurs the water flow will be reduced and at times, dramatically! The fix: clean the cartridges, backwash your sand or D.E. Filter.
Another possibility is the flow is restricted due to another type of clog: Plugged pump impeller, clogged & dirty skimmer or pump baskets, etc.
Or low water level. Sucking air with water.
Jun 10, 2014 | Hayward Pool & Spa
The water is not draining from the bottom of my fdb2810ldc1 dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 11, 2011 | Frigidaire 24 in. PLD2850 Built-in...
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
My Frigidaire dishwasher will not drain. What is the knockout plug?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Feb 20, 2011 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwasher does not clean dishes, water level sems to be low are there filters that can be cleaned as i am on a well
There may be a screen filter in the end of the hose where the water supply is connected to the water inlet valve. Turn the water off and disconnect it to clean it out.
The water level can be affected by the overflow float switch. It is in the bottom of the tub and as the water level rises it floats the switch till it shuts the water off. Pushing it down should let the water come in more. It may need cleaning.
Jan 30, 2011 | Frigidaire 24 in. FDBB540 Built-in...
My frigidaire ultra quiet will not drain
Hi
Daniel
Nov 27, 2010 | Frigidaire Dishwashers
It won't pump out the water.
Hi
Oct 25, 2010 | Frigidaire Dishwashers
Water will not drain out
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
