Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water runs after unit is shut off and door is open
Water trickles out continuously out of the inside rubber gasket hole. It seems to be only hot water. I have to run the cycle through again a couple times to get it to stop. There are no error codes since the cycle is completly through and the door is open.
    New Friend:
  • 88 Answers
It could be 1 of 2 things either your water valve is going bad or the screens on the back were the hoses connect are dirty.
Posted on Jan 11, 2009
The power will not shut off
Usually in a miele dishwasher when the power does not shut off this is due to a leak condition in which the pump is trying to pump any access water due to a leak out of the unit in which the drain pump of the unit will run continueously to avoid water to come out of the sealed bottom and spill all over your floor. One of the first things that would distinguish if this were the case in your unit, would be if you could hear the drain pump running. This can also happen if you have a clog either in the drain pump or in the drain line or in the port hole where the drain pushes the water into your disposal. If you do not hear the drain pump running. As to the door latch it basicly tells the control that the door is either opened and not to turn on the cycle or closed and then to turn on the cycle and begin to wash. You can also check to assure that you have no leaks by pulling the unit out by deinstalling the unit and removeing the bottom base panel to see if there is any water inside. If you find there is no water and no clogs and you do not hear the drain pump working message me back for further diagnosis. I await your reply.
Thank you
Rick
Nov 02, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Water has leaked from bottom
do you mean from the bottom of door? if so open door and run your fingers around the rubber gasket to see if there is any forign matter or rips, and check the small drain hole on the inside bottom of gasket, if there is a tear you could repair with a bicycle innertube repair patch
Nov 08, 2010 | LG WM-2277HW Front Load Washer
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Oct 16, 2009 | Home
Water in Passenger footwell
Tracking water leakage in cars is often not easy. However, in your case, I would start with the windshield. Was it recently replaced? If so, the seal might not be fine. Check the windshield rubber trim cover that runs around the top and bottom of the windshield to see if it is coming off from the frame of the car. It doesn't take much for water to get behind it if it is even slightly up.
While you are doing that, check around the top of the door frame. Many a time, water will travel down the contour of the door by the hinges and enter the footwell area if the rubber gasket has been compromised in any way.
Finally, check to make sure that the firewall of the vehicle does not have any rusted hole or improperly installed rubber bushing or gasket on the firewall that could allow water to run along any wires or cables there and trickle into the vehicle. I hope I have been able to help you with this problem. Good luck.
Aug 21, 2009 | 2001 Audi A4
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Water runs out of the rubber gasket inside the door
replace water inlet vale it has gotten debris in it and not allowing it to close
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
43 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
