Question about HP Photosmart C8180 InkJet Printer
Hp c7280 error code B00AC771 - HP Photosmart C8180 InkJet Printer
SOURCE: error msg on a c7280 hp printer
I had this exact same problem and it is truly frustrating! I finally stumbled on this link with a solution. The problem really is that when you make a custom size envelope you measure the envelope as you look at it for height and width, then you stick it in the printer with the longest side of the envelope against the long side of the printer tray, thus the printer is reading the dimensions of the paper in reverse of your custom size. Reverse your dimensions in the custom size set up and try again. This worked for me. Here's the link to the message I read that finally helped me to figure this out:: http://h30434.www3.hp.com/psg/board/message?board.id=Printing&thread.id=4369
Good Luck!
Posted on Jul 04, 2009
  • 17 Answers
SOURCE: hp all in one c7280 error code oxc18a0001 nothing
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785
Try the above hp support center document. I know that not all errors that pop up on the printer display will be in the manual, but usually the first few characters of an error code point towards the failure.
Posted on Jul 27, 2009
  • 138 Answers
SOURCE: ERROR CODE OXC19A0027 ON AN HP FOFO SMART C7280
Hello.
Per HP web site -
Turn printer off -
unplug power cord from printer -
remove all ink cartridges -
wait 2 minutes -
plug power cord back in -
turn power back on -
install ink cartridges when prompted.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=c00551397
Posted on May 01, 2010
  • 1382 Answers
SOURCE: I have a hp c7280 printer
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Posted on Jul 18, 2010
fbibeau
  • 66 Answers
SOURCE: HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Posted on Mar 04, 2011
Hp C7280 has different error messages 00729C98 824C1800 B03FCC84 BA0803FC how can I find out what these are?
You can find troubleshooting information for your printer on HP's website. WWW.hp.com. Enter the make and model of your printer and then download a free copy of your manual for your printer. Click on troubleshooting which is near the end of the list of choices in the maual and then find error codes.
Oct 20, 2011 | HP Photosmart C7280 Printer
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Hp all in one c7280 error code oxc18a0001 nothing seems to work can not find error code in the manual
Jul 26, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C8180 InkJet Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
