Question about Car Audio & Video
Pioneer gm41a i have this pioneer amplifier and i want to install it to my home speekers.kindly refer the wiring digram of the device.
2 Suggested Answers
  • 109 Answers
SOURCE: Pioneer amplifier
Below is a list of all of the older model Pioneer amplifiers; your's isn't in it. I don't think you have a real Pioneer product but rather a knock off amp. If you locate the model number below you can follow this link to locate a manual for it: http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/ch.Amplifiers.Archived?vgnextfmt=Archived
Posted on Jun 07, 2008
Wiring digram for pioneer model deh 23
You'll find the wiring diagram in the Operation and Installation Manuals available here. Both manuals are included in the single PDF file.
Jun 18, 2012 | Pioneer Car Audio & Video
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
I canot hear any sound from my pc (xp)
install your sound device driver go here and clic on lancer la detection
www.ma-config.com
DON'T FORGET TO RATE
Jun 26, 2010 | Microsoft Windows XP Home Edition
Need to know how to rewire the stareo
try modified-life-logo.gif.com but the remote wire is the blue,
May 09, 2010 | Kenwood KDC-MP142 Car CD/ MP3 Player
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
Sep 25, 2009 | Pioneer DEH-P2000 CD Player
Soundstream300 amp how do I hook it up to my pioneer head unit
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Aug 17, 2008 | Soundstream EGA900D Car Audio Amplifier
Pioneer amplifier
Jun 04, 2008 | Car Audio & Video
Hello
Pls verify your wiring. The Pioneer DEH-P4100 uses the below speaker wiring.
whereas a typical 2000 Ford Mustang that does uses an external amplifier would be using the below wiring scheme in its two (2) connectors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Pioneer DEH-P4100
Amp prob
The speaker wire will not shut off the amp. Make sure that your power wire and ground are all connected properly. Check for any break in connections with these wires. Also check to see if your remote wire is connect properly and that there is no break in the wire. If there is a break or disconnection in any of these 3 wires, the amp will not come on. Also, check the amp fuse to see if the fuse has flown. Also check the fuse that is connected to your 12V source. If the fuse is blown, there will be not power on the amp. Check all your connections and fuse and you should find your problem
Dec 04, 2007 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
