Question about Keurig Elite B40 Coffee Maker
We have a keruig model 4o and the temp dose not seem to be hot enough please tell me what i can do to correct it thanks, John White La,Grange.N.c.
The coffee temp is appro. 140 degree and does not get any hotter no matter how long we keep it on. we have to heat the water more in the micowave oven.
    New Friend:
KEURIG will first tell you that the temperature is pre-set. then they ask if you are using room temperature water. Also you have to make sure you PUSH the K-Cup into the holder to make sure it works probably. If it is under a year old they will replace it free of charge.
Contact info from their website
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
Posted on Dec 10, 2012
  • 5 Answers
SOURCE: Hi, I have an Ultimate B66 Keurig coffee maker
Your heating unit may be going bad. You could contact Keurig and see what they will do for you. I found them to be very helpful when I had a problem with mine. The replaced the entire unit for me and had me discard my old one.
Phone:
Keurig, Inc.
Reading, MA 01867
Posted on Feb 10, 2010
SOURCE: Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Posted on Nov 01, 2008
cmccune04
  • 213 Answers
SOURCE: where can I get a motor for my Keruig coffee maker
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
mcdevito75
  • 1970 Answers
SOURCE: I need the manual for the Keruig B60 coffee maker
mcdevito75 here, Contact green mountain coffee, they handle Keurig products and accessories at, 888-879-4627 or service rep. Chris Connell at 781-205-7282 Hope this helps.
Posted on Jul 11, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: water only heats up to
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
Keurig does not make repair's or carries replacment parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Jan 05, 2011
Where dose hot wire go to from coils on la145 22hp v twin
the coil wire is only a kill wire. it goes through the wiring harness through safety switches back to the ignition switch.
Nov 10, 2016 | John Deere Garden
Heater doesnt seem to be hot enough
Go under the hood and feel the heater hoses after the engine gets up to temp, if they seem really hot then you may have a problem with the HVAC air temperature control blend door.
Nov 08, 2016 | Cars & Trucks
Admiral atw4675yq doesn't dispense warm water
Guest,
So I was lucky enough to buy the extended warranty with your same unit and when I noticed the same issue, I called the technician.
What he tells me is that this time of year, city water is too warm to require the addition of hot (71 degrees as read at the flow). Apparently to meet the Energy Star requirement, the temperatures were lowered from what they used to be.
He suggested that I wait until Dec/Jan until my cold water temp gets into the 60s and then listen for the hot to kick in intermittently.
From what I have read on the web from other customers of various other makes and models, this problem does not seem to be restricted to Admiral.
Hope that helps. Take care and have a good day.
Mar 14, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Model MDE4000AYW, Dryer runs full hot no matter where I set the temp selector. It appears the temp selector may be bad? The sliding selector seems to have 0 resit.(open cir) white to black. Thanks for...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
May 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My 1996 Ford Explorer heater control seems to be stuck somehow. It constantly blows hot air, even when the control knob is turned to the coldest position there is no change in temp. I have checked out...
Since you're talking about the white box it sounds like you're familiar enough to proceed a bit further. Remove the three screws (8mm head) and lift the blend boor actuator off (white box). Manually move the blend door and see if your temp changes. These blend doors have plastic gears inside that strip and don't allow full movement. If you have a change in temperature then replace the actuator.
Apr 04, 2011 | 1996 Ford Explorer
The temp gauge keeps going to hot the it goes back down, its blowing white smoke from the exhaust,
junk head gaskets..since when is getting paid to help someone with an issue such a big deal..your a loser john for not taking 30 second out of your day to tell this person whats wrong
Dec 19, 2010 | 2005 Chevrolet Equinox
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
I recently converted my Frigidaire Dryer "Model GLER341A52" from a 3-prong to a 4-prong outlet. I matched the color coding, "orange to orange", "white to white", "black...
heres a rule of thum,the white wire always goes to the middle terminal then the two legs one on each side and ground to the g other green or to the cabinet,if that's not the problem it sounds like your hi temp thermostat is not cycling,if you have a volt meter with clap you can put it on amps and clip to one side of power cord to check,you should get from 3-5 amps and then when it cycles off about 1 amp,if you don't you have to replace the high temp thermostat,let me know,thanks-mike
Jun 23, 2008 | Frigidaire Dryers
Dial gets stuck
MOST DISHWASHERS HAVE A PAUSE DURING THE HEAT
CYCLE IF TH WATER ISN'T HOT ENOUGH OR IF A HIGH
TEMP WASH IS SELECTED. NORMALLY, THE TIMER WILL
ADVANCE WHEN THE TEMP IS HOT ENOUGH TO TRIP THE
THERMOSTAT. IF IT NEVER GOES PAST THAT POINT, THERE MAY BE A FAILURE IN THE HEATER CIRCUIT.
Feb 03, 2008 | Danby 22 in. DDW396 Free-standing...
Keurig Elite B40 Coffee Maker Logo
232 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
