My frontloader shuts off before the wash is complete!
It takes forever for a 38 minute wash. Once it is finally done, the clothes are still wet.
  • 15,935 Answers
The timer is faulty. Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
My dryer will run for a couple of minutes then shut off we already replaced the heating element
If your dryer has electronic sensors like this:
They might have a coating builtup on them preventing them from feeling the wet clothes.As the wet clothes tumble in the dryer they rub up against these sensor strips. As long a wetness is there the capacitor is dicharged on the controls upstairs and it continues to dry them wet clothes. If junk gets on them sensors no wetness will e felt by them sensors. It is a simple as that. The dryer thinks the clothes is dry because no dampness is being detected so is shuts down thinking all is propah. Get some windex and scrub them sensors good so dampness can be sensed by the two sensors once more and party on!
Jul 23, 2011 | Dryers
Washing machine cycle
check the lid switch for failure - or else the motor controller should be tested.
Aug 07, 2009 | Washing Machines
Duet Washer, clothes dripping wet
set it for a drain/spin cycle and watch it 12 min. doesit sound like the pump is kicking on???? if so is it removing water??? (you should hear it or see it exiting out hte drain hose.) next is it actually spinning at full speed by min 7 in the display it should start ramping up to the final full rpm spins, usually faults out if there a problem with unit itself, otherwise its a user end issue. you ARE usinf HE detergent right? not just a little less of regular soap! although it sounds good HE detergent actually designed for yuse qith the frontloading products, too much suds causes , no hide speed spin aas well as a SUD in the display
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap residue on clothes from washing machine
I have the same problem. Can't get soap out my clothes. I have a Sears Kenmore frontload washer. It seems to work fine but something isn't right. Repair man came few days ago & said NOT to use the brands they say "For ALL HE Washers" ALL being the key word. Only use the ones that only say HE. I changed back to Gain instead of Sam's brand, but I still can't get soap out. I really don't think its the detergent. I washed my daughters towels & had soap in clothes after complete full wash was done. I'm lost & have no idea what the problem is or how long its being going on before I noticed.
Dec 15, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
